Melitta Caffeo Solo microswitch on the drip tray replacement
  1. Melitta Caffeo Solo microswitch on the drip tray replacement, Opening procedure: step 1, image 1 of 1
    • Pull out the power cord!
    • Remove the water tank and drainage tray.
    • Remove the side cover and remove the brewing unit.
    • Remove all coffee beans.
    bei meiner Maschine muss ich die Schale 3-4 mal rausnehmen / einsetzten damit sich das Signal von „dauerhaft an“ auf „blinkend“ einstellt, deutet das daraufhin das der mikroschalter getauscht werden sollte. Übrigens, danke für das tolle Tutorial ..lg Tom
    Hans-A Shole - Reply
    Problem ist behoben, Schalter getauscht, Position des Schalters ist bei der Caffeo Solo 950 sehr gut erreichbar. Alter Schalter konnte auch wieder gangfähig gemacht werden und dient nun als Ersatz.
  2. Melitta Caffeo Solo microswitch on the drip tray replacement: step 2, image 1 of 1
    • Unscrew and remove six Torx T10 on the rear.
    • Lever the rear cover off. It will most likely be quite stuck and you will need to apply some force. You must use plastic lever tools to prevent damaging the cover.
  3. Melitta Caffeo Solo microswitch on the drip tray replacement: step 3, image 1 of 2 Melitta Caffeo Solo microswitch on the drip tray replacement: step 3, image 2 of 2
    • Press carefully into the slits on the sides using a minus screwdriver or a flat metal spatula, to release the clasps on the upper surface. These may be well tight and you have to use some force.
    • You should have created a separation between the upper surface and side panels. Now lever the upper covering away using a plastic tool. This may be quite stuck and you may apply some force.
  4. Melitta Caffeo Solo microswitch on the drip tray replacement: step 4, image 1 of 1
    • Place a plastic tool in the crack between front panel and left side panel and widen it. Then push the side panel to the back. The side panel will be quite stuck and you may apply some force to do this.
    • Remove the hose from the water tank to the pump.
    • Remove the side panel.
    Hi, I have a Melitta Caffeo Solo E950 and had a problem with the switch (it said that the drainage tray was always in while I removed it).
    I was able to access the switch right after the step 4 behind the side panel.
    Paul
    Paul - Reply
  5. Melitta Caffeo Solo microswitch on the drip tray replacement: step 5, image 1 of 1
    • Place a plastic tool into the crack between the front panel and the right side panel and widen it. Then push the side panel to the back. This may be quite stuck and you may need to apply some force.
  6. Melitta Caffeo Solo microswitch on the drip tray replacement, Microswitch on the drip tray: step 6, image 1 of 2 Melitta Caffeo Solo microswitch on the drip tray replacement, Microswitch on the drip tray: step 6, image 2 of 2
    • The micro switch is a little bit hidden behind cables. It is held by latches.
    • Push the cables aside, loosen the catches with a metal spudger and take the switch out.
    • Note how the cables are connected, disconnect the flat plugs and replace the switch.
    • Note: it may happen that only the carrier plate of the microswitch is no longer properly engaged. Tilt the machine so that you can see the base plate. See if the carrier plate is clamped with two catches. Press firmly on the microswitch until the plate engages. It may have to be replaced.
Follow the the steps in reverse order to reassemble your device.
6 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
247,732 Reputation
281 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
29 Members
1,752 Guides authored
7 Comments
bei meiner Maschine muss ich die Schale 3-4 mal rausnehmen / einsetzten damit sich das Signal von „dauerhaft an“ auf „blinkend“ einstellt, deutet das daraufhin das der mikroschalter getauscht werden sollte. Übrigens, danke für das tolle Tutorial ..lg Tom bei meiner Maschine muss ich die Schale 3-4 mal rausnehmen / einsetzten damit sich das Signal von „dauerhaft an“ auf „blinkend“ einstellt, deutet das daraufhin das der mikroschalter getauscht werden sollte. Übrigens, danke für das tolle Tutorial ..lg Tom
Hey guys, gibt es noch eine Art wie die Maschine "sieht" dass die Tropfschale voll ist? Grüße Ben
Ben - Reply
Hello, I tried to replace the dip tray switch. It seems to work now, but I think I reassembled it back wrongly.
Now, after coffee is grinded, it falls down to a dip tray directly, also, water is being sucked but no hose is filled with coffee and nothing comes out. The main heating unit is super hot but does not provide coffee or water further.
Any idea what can be causing that? All places stick and fit back together.
All water hoses are attached, the only thing I did was to remove two cables from the dip tray switch and I put them back, it seems to work well.
Adam Grigor - Reply
Follow the way of the water, somewhere it seems to be clogged. Pull off the hose on the pump and try to get some water (Caution!!). Does it flow? Pull off the hose on other side of the heater and blow into it - does the air get through? Same procedure for the flowmeter. Good luck!
VauWeh -
Thanks a lot for a quick reply. I’m on a verge of giving up here, but I’ll try out your tips! Thanks big time for giving me hope
Adam Grigor - Reply
Hello, both questions I can answer “yes, all ok”
But I’m not sure where is flow meter, which part is it?
When I try to make a coffee now, the heater unit gets very hot, there is a hot air blowing around it, and no water is coming out further.
It worked all well before I attempted to replace the dip tray switch, I don’t think I touched any cables or did anything wrong (but most likely I did).
Tried my best but I’m stuck now.
Anyway, thanks a lot for help!
Adam Grigor - Reply
Super tutorial Thankx. Offcourse I forgot to mark the wires so I have no idea wich of the two goes where on the microswitch. I Think it doesn't matter. Am I right?
I found that the switch was faulty because connecting the wires got the machine operating again. Tomorrow I get a new switch. regards Andre
André Pont - Reply
Past 24 Hours: 4
Past 7 Days: 39
Past 30 Days: 145
All Time: 9,369
