Munchkinz Camera Replacement
  1. Munchkinz Camera Replacement, Opening Device: step 1, image 1 of 1
    • Insert spudger into the USB Micro slot and pry the case apart.
    • Be careful not to go too deep and bend the prong inside the Micro USB port.
  2. Munchkinz Camera Replacement, Pry Device Apart: step 2, image 1 of 2 Munchkinz Camera Replacement, Pry Device Apart: step 2, image 2 of 2
    • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
    • Gently separate the case so none of the cords inside are disconnected
  3. Munchkinz Camera Replacement, Separated Device: step 3, image 1 of 1
    • After prying the device apart, it should look like this.
  4. Munchkinz Camera Replacement, Pry Camera: step 4, image 1 of 1
    • Use the slim plastic opening tool to pry the camera from its initial position.
  5. Munchkinz Camera Replacement, Disconnect Ribbon: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Use the precision tweezers to gently disconnect the camera ribbon that is connected to the motherboard.
David Wood
440 Reputation
4 Guides authored
UW Tacoma, Team 3-6, Rose Winter 2015 Member of UW Tacoma, Team 3-6, Rose Winter 2015
UWT-ROSE-W15S3G6
3 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 188
