Munchkinz LCD Assembly
  1. Munchkinz LCD Assembly, Opening Device: step 1, image 1 of 1
    • Insert spudger into the USB Micro slot and pry the case apart.
    • Be careful not to go too deep and bend the prong inside the Micro USB port.
  2. Munchkinz LCD Assembly, Pry Device Apart: step 2, image 1 of 2 Munchkinz LCD Assembly, Pry Device Apart: step 2, image 2 of 2
    • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
    • Gently separate the case so none of the cords inside are disconnected
  3. Munchkinz LCD Assembly, Separated Device: step 3, image 1 of 1
    • After prying the device apart, it should look like this.
  4. Munchkinz LCD Assembly, Remove Speaker: step 4, image 1 of 1
    • Use the plastic opening tool to remove the speaker from the casing.
  5. Munchkinz LCD Assembly, Pry Camera: step 5, image 1 of 1
    • Use the slim plastic opening tool to pry the camera from its position.
  6. Munchkinz LCD Assembly, Unscrew Volume Module: step 6, image 1 of 2 Munchkinz LCD Assembly, Unscrew Volume Module: step 6, image 2 of 2
    • Unscrew the two screws that hold the volume module to the casing.
  7. Munchkinz LCD Assembly, Pry Battery: step 7, image 1 of 1
    • Use the plastic opening tool to slowly pry each side of the battery up.
    • Be careful not to bend the battery too much.
  8. Munchkinz LCD Assembly, Remove Ribbons: step 8, image 1 of 1
    • Remove the two highlighted ribbons from the motherboard.
  9. Munchkinz LCD Assembly, Remove Screws: step 9, image 1 of 1
    • Use the screw driver to remove the highlighted screws.
  10. Munchkinz LCD Assembly, Remove Hidden Screw: step 10, image 1 of 1
    • Use the plastic opening tool to hold the camera ribbon back.
    • Unscrew the screw under ribbon with the screw driver.
  11. Munchkinz LCD Assembly, Remove Motherboard: step 11, image 1 of 1
    • Remove the motherboard from the casing.
  12. Munchkinz LCD Assembly, Pry Up Screen: step 12, image 1 of 3 Munchkinz LCD Assembly, Pry Up Screen: step 12, image 2 of 3 Munchkinz LCD Assembly, Pry Up Screen: step 12, image 3 of 3
    • Oriented the device so the battery is closest to the user.
    • Use the plastic opening tool to pry the clips up to release LCD screen.
    • Gently lift the northern end of the screen and slide it out horizontally.
  13. Munchkinz LCD Assembly, Solder LCD Wires: step 13, image 1 of 1
    • Unsolder the black and red LCD wires.
David Wood
440 Reputation
4 Guides authored
UW Tacoma, Team 3-6, Rose Winter 2015 Member of UW Tacoma, Team 3-6, Rose Winter 2015
UWT-ROSE-W15S3G6
3 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 439
