Munchkinz Volume Button assembly
  1. Munchkinz Volume Button assembly, Opening Device: step 1, image 1 of 1
    • Insert spudger into the USB Micro slot and pry the case apart.
    • Be careful not to go too deep and bend the prong inside the Micro USB port.
  2. Munchkinz Volume Button assembly, Pry Device Apart: step 2, image 1 of 2 Munchkinz Volume Button assembly, Pry Device Apart: step 2, image 2 of 2
    • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
    • Gently separate the case so none of the cords inside are disconnected
  3. Munchkinz Volume Button assembly, Separated Device: step 3, image 1 of 1
    • After prying the device apart, it should look like this.
  4. Munchkinz Volume Button assembly, Pry Camera: step 4, image 1 of 1
    • Use the slim plastic opening tool to pry the camera from its initial position.
  5. Munchkinz Volume Button assembly, Disconnect Ribbon: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Use the precision tweezers to gently disconnect the camera ribbon that is connected to the motherboard.
  6. Munchkinz Volume Button assembly, Volume Button: step 6, image 1 of 1
    • Remove the plastic volume button.
  7. Munchkinz Volume Button assembly, Unscrew Module: step 7, image 1 of 1
    • Remove the two screws that hold the volume button assembly in place.
  8. Munchkinz Volume Button assembly, Solder Module Wires: step 8, image 1 of 1
    • Un-solder the yellow, red, and black wires that connect the volume module to the motherboard.
David Wood
440 Reputation
4 Guides authored
UW Tacoma, Team 3-6, Rose Winter 2015 Member of UW Tacoma, Team 3-6, Rose Winter 2015
UWT-ROSE-W15S3G6
3 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 9
All Time: 352
