This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Why! NH57ADS CPU Replacement
  1. Why! NH57ADS CPU Replacement, Battery: step 1, image 1 of 3 Why! NH57ADS CPU Replacement, Battery: step 1, image 2 of 3 Why! NH57ADS CPU Replacement, Battery: step 1, image 3 of 3
    • Remove the two screws holding the battery in place.
    • Slip your finger into the finger hole provided at the top of the battery and lift to remove it.
  2. Why! NH57ADS CPU Replacement, Bottom Cover: step 2, image 1 of 3 Why! NH57ADS CPU Replacement, Bottom Cover: step 2, image 2 of 3 Why! NH57ADS CPU Replacement, Bottom Cover: step 2, image 3 of 3
    • Remove the five Phillips screws securing the bottom to the case.
    • Slide the cover up slightly to release the catches holding it in place. This is the view on the right. The mark on the cover should now line up with the second mark on the case of the computer.
  3. Why! NH57ADS CPU Replacement, Removing the Bottom Cover: step 3, image 1 of 3 Why! NH57ADS CPU Replacement, Removing the Bottom Cover: step 3, image 2 of 3 Why! NH57ADS CPU Replacement, Removing the Bottom Cover: step 3, image 3 of 3
    • This is the view on the left before and after sliding the cover. The mark on the cover should now line up with the second mark on the case of the computer.
    • Lift the bottom cover to remove it.
  4. Why! NH57ADS CPU Replacement, Fan: step 4, image 1 of 3 Why! NH57ADS CPU Replacement, Fan: step 4, image 2 of 3 Why! NH57ADS CPU Replacement, Fan: step 4, image 3 of 3
    • Remove the three Phillips screws securing the fan on the right.
    • Carefully unplug the fan's power connector.
    • Remove the first fan.
  5. Why! NH57ADS CPU Replacement, Fan and Heatsink Assembly: step 5, image 1 of 3 Why! NH57ADS CPU Replacement, Fan and Heatsink Assembly: step 5, image 2 of 3 Why! NH57ADS CPU Replacement, Fan and Heatsink Assembly: step 5, image 3 of 3
    • Remove the two Phillips screws securing the left hand fan.
    • Remove the six Phillips heatsink retaining screws .
    • Using the two black tabs as handles, lift and remove the heatsink.
  6. Why! NH57ADS CPU Replacement, CPU: step 6, image 1 of 3 Why! NH57ADS CPU Replacement, CPU: step 6, image 2 of 3 Why! NH57ADS CPU Replacement, CPU: step 6, image 3 of 3
    • Carefully pull the metal bar away from the processor to free it from under the retaining tab, then lift it to release the processor pins.
    • Gently remove the processor by lifting it straight up.
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
50%
Jerry Wheeler is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
31,100 Reputation
264 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 10
All Time: 148
