You're viewing a previously published version of this guide.  View latest version
Older Newer
Nikon D80 Main Board Replacement
Sara Martin
Sara Martin and 4 other contributors
Last updated on May 7, 2024
45 minutes
Difficult
Introduction
Go to step 1
Excessive use sometimes causes certain ports, such as the AV Port, to cease normal function. This guide explains how to remove the main board from a Nikon D80 camera. For safety purposes, please remove the battery before working with any electronic components.
Please note that this guide requires soldering. For more information on how to solder and desolder connections, please visit this guide.
Tools
Show more…
  1. Nikon D80 Main Board Replacement, Main Board: step 1, image 1 of 2 Nikon D80 Main Board Replacement, Main Board: step 1, image 2 of 2
    • Using a Phillips #00 screwdriver, remove the four 6.2 mm screws from the left and right sides of the outer cover.
  2. Nikon D80 Main Board Replacement: step 2, image 1 of 3 Nikon D80 Main Board Replacement: step 2, image 2 of 3 Nikon D80 Main Board Replacement: step 2, image 3 of 3
    Tool used on this step:
    • Use tweezers to gently flip the small locking flap of the zero force insertion connector up.
    • Pull the orange connector cable out of the zero force insertion connector using the tweezers.
    • Remove the back cover.
  3. Nikon D80 Main Board Replacement: step 3, image 1 of 3 Nikon D80 Main Board Replacement: step 3, image 2 of 3 Nikon D80 Main Board Replacement: step 3, image 3 of 3
    • Use a Phillips #00 screwdriver to remove the six 3.7 mm screws.
    • Remove the back plate that covers the main board.
  4. Nikon D80 Main Board Replacement: step 4, image 1 of 2 Nikon D80 Main Board Replacement: step 4, image 2 of 2
    • Use a Phillips #00 screwdriver to unscrew the 2.3 mm screw.
  5. Nikon D80 Main Board Replacement: step 5, image 1 of 1
    • Use tweezers to gently flip the small locking flaps of the zero force insertion connectors up.
    • Pull the bottom orange connector cable out of the zero force insertion connector using the tweezers.
    • Pull the top orange connector cable out of the zero force insertion connector using the tweezers.
    • Remove the ribbon cables by gently pulling them away from the no-fuss ribbon cable connectors.
    • Disconnect the main board from the two ports on the left by pulling the main board to the right.
  6. Nikon D80 Main Board Replacement: step 6, image 1 of 3 Nikon D80 Main Board Replacement: step 6, image 2 of 3 Nikon D80 Main Board Replacement: step 6, image 3 of 3
    • Using the soldering iron, disconnect the four wires soldered to the main board.
    • For more information on how to solder and desolder connections, please visit this guide.
    • Be careful when using the hot soldering iron. Move the ribbon cable out of the way as well; it is easy to burn it or yourself when using the iron.
    • Remove the main board.
Sara Martin
586 Reputation
4 Guides authored
USF Tampa, Team S1-G1, Leahy Fall 2017 Member of USF Tampa, Team S1-G1, Leahy Fall 2017
USFT-LEAHY-F17S1G1
4 Members
5 Guides authored
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 28
All Time: 2,544
