Panasonic ES-RF31 Battery Replacement
  1. Panasonic ES-RF31 Battery Replacement, Battery: step 1, image 1 of 3 Panasonic ES-RF31 Battery Replacement, Battery: step 1, image 2 of 3 Panasonic ES-RF31 Battery Replacement, Battery: step 1, image 3 of 3
    • Loose the screw at the bottom part of the razor
  2. Panasonic ES-RF31 Battery Replacement, Removing the Backcover: step 2, image 1 of 3 Panasonic ES-RF31 Battery Replacement, Removing the Backcover: step 2, image 2 of 3 Panasonic ES-RF31 Battery Replacement, Removing the Backcover: step 2, image 3 of 3
    • Slide the cover from top to bottom
  3. Panasonic ES-RF31 Battery Replacement, Removing the Batterycover: step 3, image 1 of 2 Panasonic ES-RF31 Battery Replacement, Removing the Batterycover: step 3, image 2 of 2
    • Loosen these eight screws
  4. Panasonic ES-RF31 Battery Replacement, Removing the Battery Cover: step 4, image 1 of 2 Panasonic ES-RF31 Battery Replacement, Removing the Battery Cover: step 4, image 2 of 2
    • Insert an opening tool into the gap
    • Gently remove the battery cover
  5. Panasonic ES-RF31 Battery Replacement, Removing the Battery: step 5, image 1 of 2 Panasonic ES-RF31 Battery Replacement, Removing the Battery: step 5, image 2 of 2
8 other people completed this guide.
Daniel
991 Reputation
2 Guides authored
iFixit EU Team Member of iFixit EU Team
Staff
37 Members
1,217 Guides authored
5 Guide Comments
Thanks Daniel,
I followed your instructions and all went well. One thing to add: after re-assembly of the (loaded) battery my razor would not turn on. At first I thought of a bad contact, but it turned out that the razor needed a few minutes plugged into the power supply. After that it worked fine. I suspect, that the load-control hardware needs the external power to reset itself.
Cheers, Nils
Nils Kay - Reply
Hello Nils!
Thanks for the hint.
Glad to hear that your razor works again!
Greetings
Daniel - Reply
Daniel, thank you very much for instruction.
Unfortunetly, into shaver I found only 1 battery.
Because used 3.7 v element, I prepared 2 x 1.2 v batteries.
Виктор Богачёв - Reply
My razor was the Panasonic ES8103S and the disassembly process was similar. From the pictures above, the battery looks the same. My razor actually had a piece under the slide-off cover that was totally rusted so I will just buy a new one on Amazon for $50. For future reference, I would like to know where you get the replacement battery? There is no model number on the battery and I couldn’t find any info online.
David Paul - Reply
A great guide, I have just successfully changed my razor battery. I found the OE battery available on Ebay in the UK. Many thanks to Daniel and kudos to Panasonic for making the job simple.
Cameron - Reply
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 173
All Time: 8,483
