PlayStation 2 Slimline SCPH-900xx Clock Battery Replacement
  1. PlayStation 2 Slimline SCPH-900xx Clock Battery Replacement, Lower Smart Plate: step 1, image 1 of 1
    • Turn off your PlayStation 2 and remove the disc and Memory Card.
    • Turn over the PlayStation 2 and put it on a soft surface (e.g. a towel).
  2. PlayStation 2 Slimline SCPH-900xx Clock Battery Replacement: step 2, image 1 of 1
    • Locate the six covers.
    • Two are located underneath the feet.
    • One cover is located underneath the Void sticker.
  3. PlayStation 2 Slimline SCPH-900xx Clock Battery Replacement: step 3, image 1 of 1
    • Remove the Void sticker with a Spudger and some cleaning alcohol
    • Removing the Void sticker will void the warranty of your device!
    • Some versions of that console maybe don’t have the sticker or it’s relocated.
  4. PlayStation 2 Slimline SCPH-900xx Clock Battery Replacement: step 4, image 1 of 2 PlayStation 2 Slimline SCPH-900xx Clock Battery Replacement: step 4, image 2 of 2
    • Remove the covers by using either a Spudger, Opening Picks or your fingernail.
  5. PlayStation 2 Slimline SCPH-900xx Clock Battery Replacement: step 5, image 1 of 1
    • Remove the six Phillips #1 screws with a screwdriver.
    • The screws on the right are a bit deeper inside the shell as like the rest but are the same size.
  6. PlayStation 2 Slimline SCPH-900xx Clock Battery Replacement: step 6, image 1 of 2 PlayStation 2 Slimline SCPH-900xx Clock Battery Replacement: step 6, image 2 of 2
    • Separate the clips at the front and the overhanging side from their mounting using a Prying Tool.
    • Separate the two halves.
  7. PlayStation 2 Slimline SCPH-900xx Clock Battery Replacement, Clock Battery: step 7, image 1 of 1
    • The clock battery is located under the drive.
    • Do not touch the Laser (red circle)! Otherwise it can’t read the disc anymore!
    • Make sure that the sensor array for the on/off switch sits correctly when reassembling the device.
    • This picture shows the European model (SCPH-90004). Some models with other region codes may not have a clock battery.
  8. PlayStation 2 Slimline SCPH-900xx Clock Battery Replacement: step 8, image 1 of 1
    • Pull away the metal mounting on the right to remove the old button cell.
    • Replace the old button cell/clock battery with a new button cell type CR 2032 with 3V of voltage.
8 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
MrJulian
2,157 Reputation
7 Guides authored
5 Comments
Simple and easy to follow. I really do miss how straightforward it used to be to take apart game consoles.
Melsypoo - Reply
Everything is okay but how I can extract drive?
Memozit - Reply
Hey Memozit,
To remove the optical drive of the PS2 follow this guide: PlayStation 2 Slimline SCPH-900xx Optical Drive Replacement
Greetings
MrJulian
MrJulian -
I opened up my slim silver ps2 scph-90001, can't find the cmos battery anywhere. It's not under the fan, it's not under the motherboard. This is the American silver version. I have the replacement battery I just don't know where to put it.
Cory - Reply
Hey Cory,
The PS2 shown in the guide is a European model (SCPH-90004) which has a CMOS battery. The guide mentions that other region models may not have a clock battery which could be the case on 01 models (Northern America).
Greetings
MrJulian
MrJulian -
Past 24 Hours: 18
Past 7 Days: 106
Past 30 Days: 369
All Time: 13,036
