Repairing Patagonia Jacket with a Shaped Baffle
  1. Repairing Patagonia Jacket with a Shaped Baffle, Repairing Patagonia Jacket with a Shaped Baffle: step 1, image 1 of 3 Repairing Patagonia Jacket with a Shaped Baffle, Repairing Patagonia Jacket with a Shaped Baffle: step 1, image 2 of 3 Repairing Patagonia Jacket with a Shaped Baffle, Repairing Patagonia Jacket with a Shaped Baffle: step 1, image 3 of 3
    • Examine the damage on your jacket, cutting off any loose threads and freeing any debris
    • Our garment has holes in two of the baffle segments, but we will just work on one for this guide.
    • Choose some patch fabric.
    • Why not choose a fun color? We did.
    • Select thread that matches your patch fabric, and load it into your sewing machine.
    • Select thread that matches the lining of your jacket, and load it into the bobbin of your sewing machine.
  2. Repairing Patagonia Jacket with a Shaped Baffle: step 2, image 1 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 2, image 2 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 2, image 3 of 3
    • Trace the shape of your baffle onto some cardstock or heavy paper.
    • Cut out the shape of the baffle; this will be your template.
    • Place the template over the baffle to ensure that the shape and size of your template is correct.
  3. Repairing Patagonia Jacket with a Shaped Baffle: step 3, image 1 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 3, image 2 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 3, image 3 of 3
    • Set your iron to the appropriate setting—in our case, nylon—and iron your patch fabric to smooth out any wrinkles.
    • Position the template on the patch fabric, leaving about ¼ or ½ inch of extra fabric around the edges.
    • Cut out the patch, leaving 1/4 or 1/2 inch of extra fabric around each side of the template.
  4. Repairing Patagonia Jacket with a Shaped Baffle: step 4, image 1 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 4, image 2 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 4, image 3 of 3
    • Fold the edge of the fabric over, creating a fold at the edge of the template.
    • Carefully hold the fabric in place and iron it down.
  5. Repairing Patagonia Jacket with a Shaped Baffle: step 5, image 1 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 5, image 2 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 5, image 3 of 3
    • Work around the template, folding each side in, and ironing it into place.
  6. Repairing Patagonia Jacket with a Shaped Baffle: step 6, image 1 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 6, image 2 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 6, image 3 of 3
    • Slide the template out of the patch.
    • Refold along the creases you previously ironed.
    • Turn the patch over so that the right-side, or the side that will be showing, is up and press it.
  7. Repairing Patagonia Jacket with a Shaped Baffle: step 7, image 1 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 7, image 2 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 7, image 3 of 3
    • Align the patch with the baffle, exactly as you want it to appear when you are done.
    • Slide the garment into the sewing machine, repositioning the patch if necessary.
    • To prevent the insulation from leaking through the stitches, fir your sewing machine with the smallest needle available.
    • Sink the needle to hold the patch into place.
    • Do not pin the patch, as this will create unnecessary holes where down can escape.
    • Holding the patch in place sew directly over the edge of your patch.
  8. Repairing Patagonia Jacket with a Shaped Baffle: step 8, image 1 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 8, image 2 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 8, image 3 of 3
    • When you come to the corner of your patch, sink the needle.
    • Lift the presser foot, leaving the needle in the fabric, and gently turn the fabric 90 degrees, aligning it with the edge of the patch.
    • Drop the presser foot and continue sewing along the second edge of the patch.
    • Be sure to hold the patch in place as you sew.
  9. Repairing Patagonia Jacket with a Shaped Baffle: step 9, image 1 of 2 Repairing Patagonia Jacket with a Shaped Baffle: step 9, image 2 of 2
    • As you did with the first corner, sink the needle, lift the presser foot, and rotate the garment.
    • Drop the presser foot and continue sewing on the third edge of the patch.
  10. Repairing Patagonia Jacket with a Shaped Baffle: step 10, image 1 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 10, image 2 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 10, image 3 of 3
    • Repeat step nine for the last corner, and sew the final edge of the patch in place.
    • Backstitch when you come to the end of the patch.
  11. Repairing Patagonia Jacket with a Shaped Baffle: step 11, image 1 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 11, image 2 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 11, image 3 of 3
    • Lift the needle and presser foot, freeing the garment from the sewing machine.
    • Clip any threads, and admire your work!
Finish Line
6 other people completed this guide.
Brittany McCrigler
89,113 Reputation
131 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,895 Guides authored
One Comment
hello, I hope this finds you well.
Can I buy repair fabric from Patagonia? My jacket seems to attract rips. And the local tailor does a fast and good job.
Thanks!
Andrew
Andrew Chepaitis - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 37
All Time: 17,954
