Retro-Bit Retro Duo Reset Button/Power Switch Replacement
  1. Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: step 1, image 1 of 3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: step 1, image 2 of 3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: step 1, image 3 of 3
    • With the console on its top. Remove the four 12 mm Phillips #2 screws.
    • There may be a sticker covering one, or more, of the screws. Simply remove the it before the screws.
    • Flip the console on its feet and carefully lift the top casing from the back (where the AV/S and power ports are).
    • To avoid damage, do not completely remove the top case. There is a small circuit board--which houses two LEDs-- connected to the main circuit board.
  2. Retro-Bit Retro Duo Reset Button/Power Switch Replacement: step 2, image 1 of 3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: step 2, image 2 of 3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: step 2, image 3 of 3
    • Remove the one 6 mm Phillips #0 screw.
    • Lift the top case.
    • This step allows easy button access and prevents accidental damage.
  3. Retro-Bit Retro Duo Reset Button/Power Switch Replacement: step 3, image 1 of 3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: step 3, image 2 of 3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Using your fingers (or precision tweezers), carefully pinch the button tabs and push through to the other side.
    • Make sure you pinch both tabs simultaneously, or the button will not pop out.
If the problem persists after the buttons are replaced, it may be a circuit board issue. If so, please visit our guide for circuit board replacement at Retro-Bit Retro Duo Circuit Board Replacement
Truong Vo
320 Reputation
3 Guides authored
USF Tampa, Team S4-G4, Eyestone Fall 2017 Member of USF Tampa, Team S4-G4, Eyestone Fall 2017
USFT-EYESTONE-F17S4G4
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 793
