Samsung Chromebook series 5 XE550C22 SSD Replacement
  1. Samsung Chromebook series 5 XE550C22 SSD Replacement, Back Panel: step 1, image 1 of 3 Samsung Chromebook series 5 XE550C22 SSD Replacement, Back Panel: step 1, image 2 of 3 Samsung Chromebook series 5 XE550C22 SSD Replacement, Back Panel: step 1, image 3 of 3
    • Turn the power off before beginning this step.
    • Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
  2. Samsung Chromebook series 5 XE550C22 SSD Replacement: step 2, image 1 of 2 Samsung Chromebook series 5 XE550C22 SSD Replacement: step 2, image 2 of 2
    • Remove the eight 7mm screws using the J0 Screwdriver.
  3. Samsung Chromebook series 5 XE550C22 SSD Replacement: step 3, image 1 of 3 Samsung Chromebook series 5 XE550C22 SSD Replacement: step 3, image 2 of 3 Samsung Chromebook series 5 XE550C22 SSD Replacement: step 3, image 3 of 3
    • Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
    • Continue prying around the sides to release more brackets.
  4. Samsung Chromebook series 5 XE550C22 SSD Replacement: step 4, image 1 of 2 Samsung Chromebook series 5 XE550C22 SSD Replacement: step 4, image 2 of 2
    • After deconnecting all the brackets, pull the back panel away from the laptop.
    • Note: The back panel has some flex to it, don't be afraid to use some force.
  5. Samsung Chromebook series 5 XE550C22 SSD Replacement, Battery: step 5, image 1 of 2 Samsung Chromebook series 5 XE550C22 SSD Replacement, Battery: step 5, image 2 of 2
    • Remove the four 3mm screws holding the battery with the J0 screwdriver.
  6. Samsung Chromebook series 5 XE550C22 SSD Replacement: step 6, image 1 of 2 Samsung Chromebook series 5 XE550C22 SSD Replacement: step 6, image 2 of 2
    • Lift the battery up at an angle to disconnect the battery from the motherboard, then pull it away from the laptop.
    • Do not lift the battery straight up. This will damage the battery's connectors.
  7. Samsung Chromebook series 5 XE550C22 SSD Replacement, SSD: step 7, image 1 of 1
    • Locate the SSD in the center of the Chromebook.
  8. Samsung Chromebook series 5 XE550C22 SSD Replacement: step 8, image 1 of 3 Samsung Chromebook series 5 XE550C22 SSD Replacement: step 8, image 2 of 3 Samsung Chromebook series 5 XE550C22 SSD Replacement: step 8, image 3 of 3
    • Remove the single 3.5mm screw using the J0 screwdriver.
    • The SSD should "pop-up" on its own after it's unscrewed.
  9. Samsung Chromebook series 5 XE550C22 SSD Replacement: step 9, image 1 of 2 Samsung Chromebook series 5 XE550C22 SSD Replacement: step 9, image 2 of 2
    • Pull the SSD up and away from the Chromebook
4 other people completed this guide.
Abel Osorio
330 Reputation
2 Guides authored
CSU Fullerton, Team S2-G7, Bruce Fall 2017 Member of CSU Fullerton, Team S2-G7, Bruce Fall 2017
CSUF-BRUCE-F17S2G7
3 Members
14 Guides authored
4 Comments
Hello where can I get I higher SSD to buy
aduboa moses - Reply
The SSD on the Chromebook 3 is non-upgradable. This is a different model. Please post this guide in the model you have.
frontiergds - Reply
If you want to get more storage out of your chromebook get a sd card and you will only need it if you have a chrultrabook.
Will F - Reply
The samsung chromebook shown on this guide is Samsung Chromebook XE550C22. The samsung chromebook 3 ( XE500C13 ), is totally different model. I have edited the title and description to match the actual model.
coldspring21 - Reply
Past 24 Hours: 5
Past 7 Days: 13
Past 30 Days: 61
All Time: 5,193
