Samsung Galaxy S6 Edge Motherboard Removal
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Samsung Galaxy S6 Edge Motherboard Removal, Motherboard Removal: step 1, image 1 of 2 Samsung Galaxy S6 Edge Motherboard Removal, Motherboard Removal: step 1, image 2 of 2
    • Using the flat end of the spudger, disconnect the battery ribbon cable from the motherboard.
  2. Samsung Galaxy S6 Edge Motherboard Removal: step 2, image 1 of 2 Samsung Galaxy S6 Edge Motherboard Removal: step 2, image 2 of 2
    • Disconnect the home button ribbon cable from the motherboard.
  3. Samsung Galaxy S6 Edge Motherboard Removal: step 3, image 1 of 3 Samsung Galaxy S6 Edge Motherboard Removal: step 3, image 2 of 3 Samsung Galaxy S6 Edge Motherboard Removal: step 3, image 3 of 3
    • Use the pointed end of a spudger to disconnect the two antenna interconnect cables from the motherboard.
  4. Samsung Galaxy S6 Edge Motherboard Removal: step 4, image 1 of 2 Samsung Galaxy S6 Edge Motherboard Removal: step 4, image 2 of 2
    • Disconnect the display ribbon cable from the motherboard using the flat end of the spudger.
  5. Samsung Galaxy S6 Edge Motherboard Removal: step 5, image 1 of 2 Samsung Galaxy S6 Edge Motherboard Removal: step 5, image 2 of 2
    • Disconnect the earpiece ribbon cable from the motherboard.
  6. Samsung Galaxy S6 Edge Motherboard Removal: step 6, image 1 of 2 Samsung Galaxy S6 Edge Motherboard Removal: step 6, image 2 of 2
    • The motherboard is an ESD sensitive component and should be handled with care. iFixit recommends using a anti-static bracelet whenever handling components of this nature to avoid damage.
    • Grip the motherboard on both edges toward the top of the device.
    • Do not lift the motherboard all the way out in this step; the ribbon cable on the underside needs to be disconnected first.
    • Lift the motherboard up and away from the display, taking care not to put too much stress on the daughterboard ribbon cable.
  7. Samsung Galaxy S6 Edge Motherboard Removal: step 7, image 1 of 2 Samsung Galaxy S6 Edge Motherboard Removal: step 7, image 2 of 2
    • Disconnect the daughterboard ribbon cable from the underside of the motherboard.
Sam Goldheart
471,498 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,425 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 6
All Time: 312
