Samsung Level Box Mini Battery Replacement
  1. Samsung Level Box Mini Battery Replacement, Battery: step 1, image 1 of 2 Samsung Level Box Mini Battery Replacement, Battery: step 1, image 2 of 2
    Tool used on this step:
    Buy
    • Using a plastic opening tool, go around the edges of the rubber bottom. Insert the same tool under the edge of the rubber and swivel side to side. Continue moving it forward while peeling the plastic off with the precision tweezers.
  2. Samsung Level Box Mini Battery Replacement: step 2, image 1 of 1
    • Remove the six 4.5 mm Philips #1 screws from the bottom plate using the Screwdriver J00. Take off the bottom plate.
  3. Samsung Level Box Mini Battery Replacement: step 3, image 1 of 1
    • Using the plastic opening tool, remove the batteries from the device.
To reassemble your device, follow all the instructions in the reverse order. Use adhesive to stick the rubber back onto the bottom of the device.
9 other people completed this guide.
dylan weiss
134 Reputation
1 Guide authored
USF Tampa, Team 1-4, Kass Spring 2017 Member of USF Tampa, Team 1-4, Kass Spring 2017
USFT-KASS-S17S1G4
5 Members
4 Guides authored
5 Guide Comments
Did all above but still wont switch on..batt are ok and power gets to the battery points…what could be wrong…
dslotman5 - Reply
I want to replace pcb of this device how to find it??
faraz siddiqui - Reply
I want to replace PCB of this device suggest me where to find?
The "parts needed" list has a search for the battery misspelled in "Samsung".
Jim Plosay - Reply
What kind of batterries should get ?
Aldo Eliezer Rivera Sizzo - Reply
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 65
All Time: 9,687
