Siemens Surpresso brewing unit maintenance
  1. Siemens Surpresso brewing unit maintenance, Brewing Unit maintenance: step 1, image 1 of 1
    • Remove the brewing unit from the device.
  2. Siemens Surpresso brewing unit maintenance: step 2, image 1 of 1
    • Take off the cap covering the screwhole in one corner. The cap ensures a better fit of the brewing unit.
    • Note: some versions of the brewing unit do not have this cap.
  3. Siemens Surpresso brewing unit maintenance: step 3, image 1 of 1
    • Remove the single black Torx T10 screw fixing the opening handle.
    • Using a certain amount of force pull the opening handle out of the guidance near the red button.
    • Rotate the handle 90 degrees counterclockwise, then lift it off.
  4. Siemens Surpresso brewing unit maintenance: step 4, image 1 of 2 Siemens Surpresso brewing unit maintenance: step 4, image 2 of 2
    • Unclip the upper protection panel, then remove it by lifting it up.
  5. Siemens Surpresso brewing unit maintenance: step 5, image 1 of 1
    • Remove six Torx T15 screws holding together the brewing unit. The screwholes are rather deep.
    • Lift the upper half of the brewing unit up.
  6. Siemens Surpresso brewing unit maintenance: step 6, image 1 of 2 Siemens Surpresso brewing unit maintenance: step 6, image 2 of 2
    • The inside of the brewing unit ist exposed. You can see:
    • The upper piston and its gasket.
    • The funnel for the coffee grounds
    • The lower piston.
    • The hold-down clamp
  7. Siemens Surpresso brewing unit maintenance: step 7, image 1 of 3 Siemens Surpresso brewing unit maintenance: step 7, image 2 of 3 Siemens Surpresso brewing unit maintenance: step 7, image 3 of 3
    • Remove the funnel.
    • Rotate the lower piston counterclockwise and lift it off.
    • Lift off the upper piston. There ist still a hose connecting the piston to the coffee outlet. In top there ist also the downholder of the brewing unit.
    • Sometimes this downholder ist torn and the coffee leaks out of the brewing unit and does not fill your cup. Inspect the downholder for cracks. You can fix this using a special repair kit.
  8. Siemens Surpresso brewing unit maintenance: step 8, image 1 of 3 Siemens Surpresso brewing unit maintenance: step 8, image 2 of 3 Siemens Surpresso brewing unit maintenance: step 8, image 3 of 3
    • Remove the hose connecting the upper piston and the coffee outlet.
    • Remove the upper piston.
    • Remove the Torx T20 screw from the screen of the upper piston.
    • Take off the cover of the gasket and the gasket.
    • Replace the gaskets of the upper piston, the coffee outlet and water connector.
    • The lip of the piston gasket must point towards the pressure, i.e. downwards.
    • Clean thoroughly all parts. Use food-proof silicone grease to lubricate the gaskets.
  9. Siemens Surpresso brewing unit maintenance: step 9, image 1 of 1
    • The crema-valve is located in the interior of the upper piston. It is fixed by two Torx T10 screws.
    • Remove both screws. Lift off the valve. Inspect it and clean it.
    • Note: there is another gasket on the shaft of the lower piston. Replacing it is difficult.
    • Lubricate all sliding parts with food-proof silicone grease. Verify the smooth operating of the brewing unit.
To reassemble your device, follow these directions in reverse order.
4 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
247,732 Reputation
281 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
29 Members
1,752 Guides authored
16 Comments
Très intéressant tutoriel.
Une heure me semble suffisant comme temps nécessaire.
À propos de « Note: there is another gasket on the shaft of the lower piston. Replacing it is difficult », c’est justement ce joint qui semble défectueux. J’ai pu l’enlever et le remettre, mais n’en ai pas trouvé de remplacement (-:
JPKuypers - Reply
Maybe this one. It’s from Nivona, but the brewing unit is the same:
https://www.juraprofi.de/Nivona-Ersatzte...
VauWeh - Reply
I have problem with my brewing unit of Siemens EQ 3 S300. Can you have an instruction to open it?
Thanh Nguyen Duc - Reply
The Siemens EQ 3 is a total (newer) different design . There are some videos (in german), e.g. this one. Using the german word for brewing unit - “Brüheinheit” or “Brühgruppe”, you can find other videos or guides.
VauWeh -
I need the gasket of upper piston , do you know what this part number , its possible buy to siemens?
hfuso - Reply
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 97
All Time: 12,115
