Skytex SP728 Screen Replacement
  1. Skytex SP728 Screen Replacement, Case: step 1, image 1 of 1
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
  2. Skytex SP728 Screen Replacement: step 2, image 1 of 1
    • Using a small phillips screwdriver, unscrew both end screws
  3. Skytex SP728 Screen Replacement: step 3, image 1 of 1
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
  4. Skytex SP728 Screen Replacement: step 4, image 1 of 1
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
  5. Skytex SP728 Screen Replacement, Screen: step 5, image 1 of 3 Skytex SP728 Screen Replacement, Screen: step 5, image 2 of 3 Skytex SP728 Screen Replacement, Screen: step 5, image 3 of 3
    • Follow the Case Replacement to separate the tablet from its backing
    • Using a small Phillips screw driver, unscrew all screws connecting circuit board to device
    • Remove all tape connecting battery and circuit board to front case
    • Detach all connector strips from the circuit board
  6. Skytex SP728 Screen Replacement: step 6, image 1 of 2 Skytex SP728 Screen Replacement: step 6, image 2 of 2
    • Using the plastic opening tool, begin separating the front screen from the display
  7. Skytex SP728 Screen Replacement: step 7, image 1 of 1
    Tool used on this step:
    Buy
    • Once screen has been separated, use tweezers to remove front camera
To reassemble your device with a new screen, follow these instructions in reverse order.
2 other people completed this guide.
Michelle Strickland
304 Reputation
2 Guides authored
USF Tampa, Team 5-1, Brown Winter 2015 Member of USF Tampa, Team 5-1, Brown Winter 2015
USFT-BROWN-W15S5G1
4 Members
11 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 4
All Time: 309
