Sony Cyber-shot DSC-WX100 Image Sensor Replacement
  1. Sony Cyber-shot DSC-WX100 Image Sensor Replacement, Battery: step 1, image 1 of 1
    • Open the flap indicated to allow access to the battery slot.
    • The gray switch indicated has to be moved to the right in order to release the flap.
  2. Sony Cyber-shot DSC-WX100 Image Sensor Replacement: step 2, image 1 of 1
    • If the old battery is still in the slot, then make sure the camera is turned off prior to removal.
    • If there is a battery currently in the slot, remove by first pulling downwards on the blue component. This will allow you to remove the battery from the slot.
  3. Sony Cyber-shot DSC-WX100 Image Sensor Replacement, Outer Casing: step 3, image 1 of 3 Sony Cyber-shot DSC-WX100 Image Sensor Replacement, Outer Casing: step 3, image 2 of 3 Sony Cyber-shot DSC-WX100 Image Sensor Replacement, Outer Casing: step 3, image 3 of 3
    • Remove all of the 1mm screws using a Philips #000 Screwdriver.
    • Remover the rest of the screws (2mm) from the camera covers using a Phillips #000 Screwdriver.
  4. Sony Cyber-shot DSC-WX100 Image Sensor Replacement: step 4, image 1 of 2 Sony Cyber-shot DSC-WX100 Image Sensor Replacement: step 4, image 2 of 2
    • Use the plastic opening tool to gently remove the front and back plates of the camera.
  5. Sony Cyber-shot DSC-WX100 Image Sensor Replacement: step 5, image 1 of 2 Sony Cyber-shot DSC-WX100 Image Sensor Replacement: step 5, image 2 of 2
    • Use a plastic opening tool to gently release the two indicated tabs.
    • Pull up on the lower end of the plate. Lift it so that the plate is uninhibited by the indicated bump.
    • Pull away from the camera at the end of the metal plate with the blue circuits to then remove the plate from the rest of the camera.
    • For help with this step, refer to the video.
  6. Sony Cyber-shot DSC-WX100 Image Sensor Replacement: step 7, image 1 of 3 Sony Cyber-shot DSC-WX100 Image Sensor Replacement: step 7, image 2 of 3 Sony Cyber-shot DSC-WX100 Image Sensor Replacement: step 7, image 3 of 3
    • Remove this screw (1mm) with the Phillips #000 Screwdriver.
    • Gently lift the LCD screen component from the metal plate.
    • Remove the metal plate that was underneath the LCD screen from the camera.
  7. Sony Cyber-shot DSC-WX100 Image Sensor Replacement: step 8, image 1 of 3 Sony Cyber-shot DSC-WX100 Image Sensor Replacement: step 8, image 2 of 3 Sony Cyber-shot DSC-WX100 Image Sensor Replacement: step 8, image 3 of 3
    • Peel back the copper sheet.
    • Unscrew the three marked screws (2mm) using a Phillips #000 Screwdriver.
    • Remove the panel attached by said screws.
  8. Sony Cyber-shot DSC-WX100 Image Sensor Replacement: step 9, image 1 of 1
    • Peel back both the copper sheet and the black tape underneath the panel to expose the connection port.
  9. Sony Cyber-shot DSC-WX100 Image Sensor Replacement: step 10, image 1 of 3 Sony Cyber-shot DSC-WX100 Image Sensor Replacement: step 10, image 2 of 3 Sony Cyber-shot DSC-WX100 Image Sensor Replacement: step 10, image 3 of 3
    • Use a plastic opening tool to pry the black bar upwards.
    • Pull the image sensor out after the black tab is released.
2 other people completed this guide.
Matthew
583 Reputation
4 Guides authored
One Comment
thanks a lot very helpfull.
could you precise( in remounting phase) that it is necessary to take care of the position of the back slider (photo/pano/video) before screwing, it will avoid to dismount again…….
regards
Olivier TRIFT - Reply
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 7
All Time: 994
