Sony Cyber-shot DSC-WX100 Outer Casing Replacement
  1. Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Battery: step 1, image 1 of 1
    • Open the flap indicated to allow access to the battery slot.
    • The gray switch indicated has to be moved to the right in order to release the flap.
  2. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: step 2, image 1 of 1
    • If the old battery is still in the slot, then make sure the camera is turned off prior to removal.
    • If there is a battery currently in the slot, remove by first pulling downwards on the blue component. This will allow you to remove the battery from the slot.
  3. Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: step 3, image 1 of 3 Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: step 3, image 2 of 3 Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: step 3, image 3 of 3
    • Remove all of the 1mm screws using a Philips #000 Screwdriver.
    • Remover the rest of the screws (2mm) from the camera covers using a Phillips #000 Screwdriver.
  4. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: step 4, image 1 of 2 Sony Cyber-shot DSC-WX100 Outer Casing Replacement: step 4, image 2 of 2
    • Use the plastic opening tool to gently remove the front and back plates of the camera.
  5. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: step 5, image 1 of 2 Sony Cyber-shot DSC-WX100 Outer Casing Replacement: step 5, image 2 of 2
    • Use a plastic opening tool to gently release the two indicated tabs.
2 other people completed this guide.
Matthew
583 Reputation
4 Guides authored
One Comment
Where I can buy the Outer Casing..¿??
ING CHARLY - Reply
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 8
All Time: 943
