Sony Xperia Z3 Compact Battery Replacement
Tobias Isakeit
Tobias Isakeit and 5 other contributors
Last updated on March 26, 2025
45 minutes - 1 hour
Moderate
Introduction
Go to step 1
This guide shows you how to replace the battery in your Sony Xperia Z3 compact.
Follow this guide in reverse order to reassemble the device and apply new adhesive where needed.
Parts
Tools
Show more…
  1. Sony Xperia Z3 Compact Battery Replacement, Sony Xperia Z3 Compact Battery Replacement: step 1, image 1 of 3 Sony Xperia Z3 Compact Battery Replacement, Sony Xperia Z3 Compact Battery Replacement: step 1, image 2 of 3 Sony Xperia Z3 Compact Battery Replacement, Sony Xperia Z3 Compact Battery Replacement: step 1, image 3 of 3
    • Heat the back cover of your Xperia Z3 Compact with an iOpener to loosen the adhesive underneath.
    • Lift up the back cover with a suction handle and put an opening pick in the gap.
    • Move the pick carefully around the edges to loosen the adhesive on every side of the phone.
    • Now you can pull up the back cover with the suction handle.
  2. Sony Xperia Z3 Compact Battery Replacement: step 2, image 1 of 2 Sony Xperia Z3 Compact Battery Replacement: step 2, image 2 of 2
    • Use a tweezer to remove the model label which is hooked in the right side of the frame.
    • Undo the flex cable of the NFC antenna with a tweezer.
  3. Sony Xperia Z3 Compact Battery Replacement: step 3, image 1 of 2 Sony Xperia Z3 Compact Battery Replacement: step 3, image 2 of 2
    • Unscrew the following screws which hold down the mid frame of the Sony Xperia Z3 Compact.
    • Two 2.7 mm Phillips #000
    • Three 2.5 mm Phillips #000
    • Use a Spudger to lift up the mid frame on each side.
    • Be careful and patient, the plastic mid frame is fragile and might break if bent too hard.
  4. Sony Xperia Z3 Compact Battery Replacement: step 4, image 1 of 3 Sony Xperia Z3 Compact Battery Replacement: step 4, image 2 of 3 Sony Xperia Z3 Compact Battery Replacement: step 4, image 3 of 3
    • Declamp the metal bracket which holds down the flex connector of the rear camera.
    • Unplug the flex connector of the rear camera and lift it out of its recess.
  5. Sony Xperia Z3 Compact Battery Replacement: step 5, image 1 of 2 Sony Xperia Z3 Compact Battery Replacement: step 5, image 2 of 2
    • Use a Spudger to unplug the headphone jack and sensor cable connector.
    • Unscrew the single 2.5 mm Phillips #000 screw on the upper left side of the motherboard.
  6. Sony Xperia Z3 Compact Battery Replacement: step 6, image 1 of 3 Sony Xperia Z3 Compact Battery Replacement: step 6, image 2 of 3 Sony Xperia Z3 Compact Battery Replacement: step 6, image 3 of 3
    • Unplug the battery and display flex connectors.
    • Open the compartments for the SIM card and the micro SD card and remove them.
  7. Sony Xperia Z3 Compact Battery Replacement: step 7, image 1 of 3 Sony Xperia Z3 Compact Battery Replacement: step 7, image 2 of 3 Sony Xperia Z3 Compact Battery Replacement: step 7, image 3 of 3
    • Use a Spudger to slightly lift up the motherboard.
    • Be careful! You need to thread the display flex cable through a gap in the motherboard while lifting it up. It is also connected to the vibration motor, which still sticks to the phone.
    • Take especially care of the two black connectors on the side of the battery. They break off easily during the removal of the motherboard.
    • Use a tweezer to take out the vibration motor and then remove the motherboard completely.
  8. Sony Xperia Z3 Compact Battery Replacement: step 8, image 1 of 3 Sony Xperia Z3 Compact Battery Replacement: step 8, image 2 of 3 Sony Xperia Z3 Compact Battery Replacement: step 8, image 3 of 3
    Tool used on this step:
    Plastic Cards
    $2.99
    • Gently pull out both of the black straps with the adhesive tabs underneath the battery.
    • Never pull out the straps upwards but always sideways. It can easily happen that you rupture the adhesive tabs. In this case use a plastic card to pry off the battery carefully,Use a little bit of heat if necessary!
    • Now you can remove the battery from the motherboard easily.
  9. Sony Xperia Z3 Compact Battery Replacement: step 9, image 1 of 3 Sony Xperia Z3 Compact Battery Replacement: step 9, image 2 of 3 Sony Xperia Z3 Compact Battery Replacement: step 9, image 3 of 3
    • Warm up the NFC antenna a little bit to loosen the adhesive underneath.
    • Carefully peel it off the battery. If the adhesive starts to crumble use a plastic card to loosen the adhesive.
24 other people completed this guide.
Tobias Isakeit
124,032 Reputation
189 Guides authored
10 Comments
Thank you Tobias !
My Z3 compact starts now his second life :)
Guy Hard - Reply
Thank you for repairing your phone and giving it a second chance.
Tobias Isakeit -
Where do I need the Back Cover Adhesive Strips for?
Visser - Reply
The guide doesn’t mention that one needs new adhesive for the battery (the one I bought isn’t sold with it). It would therefore be wise to mention what kind of adhesive (two-sided, what thckness, etc.)
axel - Reply
Double sided tape is enough to keep it in place, as the back cover and midframe holds everything down for extra reinforcement. Sony sure makes their smartphones !&&* to repair, but that’s another rant.
William Nephew -
Past 24 Hours: 2
Past 7 Days: 40
Past 30 Days: 142
All Time: 42,143
