Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement
Rei Rutkowski
Rei Rutkowski and 4 other contributors
Last updated on July 8, 2023
25 minutes
Moderate
Introduction
Go to step 1
This guide will walk you through the process of replacing the CPU cooling fan. Cooling fans can deteriorate into a state where it loses efficiency. This state can cause loud noises and cause the computer to shut down if not properly maintained.
To do so, one must remove the back cover. The back cover is attached by not only screws, but also plastic clips.
Tools
  1. Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement, Hard Drive: step 1, image 1 of 3 Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement, Hard Drive: step 1, image 2 of 3 Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement, Hard Drive: step 1, image 3 of 3
    • Place the laptop with the bottom facing up.
    • Remove the single 6mm Phillips #1 screw keeping the laptop panels in place.
  2. Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement: step 2, image 1 of 1
    • Using the Phillips #1 screwdriver, remove the 8mm screw that is holding the hard drive in place.
  3. Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement: step 3, image 1 of 2 Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement: step 3, image 2 of 2
    • Use your finger to lift the hard drive up.
    • Pull out the hard drive to the right.
  4. Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement, CPU Cooling Fan: step 4, image 1 of 2 Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement, CPU Cooling Fan: step 4, image 2 of 2
    • Unscrew all 15 of the screws in the back cover of the laptop.
    • Carefully pry the back cover off the laptop using the prying tools, starting from the hard drive side.
  5. Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement: step 5, image 1 of 3 Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement: step 5, image 2 of 3 Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement: step 5, image 3 of 3
    • Unscrew the two silver screws attaching the fan to the case.
    • Unplug the power connector for the fan.
    • Pull the fan up out of the slot.
3 other people completed this guide.
Rei Rutkowski
184 Reputation
2 Guides authored
IUPUI, Team S8-G8, Wilson Fall 2018 Member of IUPUI, Team S8-G8, Wilson Fall 2018
IUPUI-WILSON-F18S8G8
4 Members
6 Guides authored
One Comment
The one I disassembled didn’t have a screw under the battery bay, but did have one under the HDD bay, just as described by a comment in the charge port replacement guide.
Luis Alejandro Araúz - Reply
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 8
All Time: 1,052
