Toshiba Satellite C55-A5100 Optical Drive Replacement
  1. Toshiba Satellite C55-A5100 Optical Drive Replacement, Battery: step 1, image 1 of 1
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Toshiba Satellite C55-A5100 Optical Drive Replacement: step 2, image 1 of 1
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Toshiba Satellite C55-A5100 Optical Drive Replacement, Optical Drive: step 3, image 1 of 3 Toshiba Satellite C55-A5100 Optical Drive Replacement, Optical Drive: step 3, image 2 of 3 Toshiba Satellite C55-A5100 Optical Drive Replacement, Optical Drive: step 3, image 3 of 3
    • Place laptop with the bottom of it facing up.
    • Remove the single 6mm Phillips #1 screw keeping the laptop panels in place.
  4. Toshiba Satellite C55-A5100 Optical Drive Replacement: step 4, image 1 of 1
    • Remove the 4mm Phillips #1 screw on the side of the now exposed area.
  5. Toshiba Satellite C55-A5100 Optical Drive Replacement: step 5, image 1 of 1
    • Remove the disc drive from the device.
3 other people completed this guide.
One Comment
Any idea of how tall the drive is? Is it 12.7mm or 9.5mm tall?
Luis Alejandro Araúz - Reply
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 7
All Time: 375
