Turtle Beach Recon 70P Microphone Replacement
  1. Turtle Beach Recon 70P Microphone Replacement, Microphone: step 1, image 1 of 2 Turtle Beach Recon 70P Microphone Replacement, Microphone: step 1, image 2 of 2
    • Before continuing, remove the left ear pad with the earpad replacement guide.
    • Ensure that you are removing the side that houses the microphone.
    • Use a spudger to pry up the black plastic housing.
    • Remove the plastic cover.
  2. Turtle Beach Recon 70P Microphone Replacement: step 2, image 1 of 3 Turtle Beach Recon 70P Microphone Replacement: step 2, image 2 of 3 Turtle Beach Recon 70P Microphone Replacement: step 2, image 3 of 3
    • Use a Phillips screwdriver remove the two 5 mm screws that secure the motherboard.
  3. Turtle Beach Recon 70P Microphone Replacement: step 3, image 1 of 3 Turtle Beach Recon 70P Microphone Replacement: step 3, image 2 of 3 Turtle Beach Recon 70P Microphone Replacement: step 3, image 3 of 3
    • Use a Phillips screwdriver to remove the single 8 mm screw under the motherboard that secures the microphone.
  4. Turtle Beach Recon 70P Microphone Replacement: step 4, image 1 of 3 Turtle Beach Recon 70P Microphone Replacement: step 4, image 2 of 3 Turtle Beach Recon 70P Microphone Replacement: step 4, image 3 of 3
    • You may need to move the wire connecting to the speaker to easily remove the motherboard.
    • Remove the circuit board from the housing.
    • Take care not to strain the wires.
  5. Turtle Beach Recon 70P Microphone Replacement: step 5, image 1 of 1
    • Desolder the microphone connections.
    • Soldering irons can cause burns and fires. Always solder and desolder in a well-ventilated workspace.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 36
All Time: 554
