UE BOOM 2 Micro-USB Port Replacement
Alex Bahm
Alex Bahm and one other contributor
Last updated on July 17, 2023
10 - 20 minutes
Moderate
Introduction
Go to step 1
The micro-USB port is located under a rubber cover on the bottom of the UE Boom 2 speaker. Replacing this part requires the removal of the D-ring and rubber port cover, In addition the bottom pad must be removed, which will void the device warranty.
iFixit earns commission when you buy through these links.
  1. UE BOOM 2 Micro-USB Port Replacement, Micro-USB Port: step 1, image 1 of 2 UE BOOM 2 Micro-USB Port Replacement, Micro-USB Port: step 1, image 2 of 2
    • First, remove the D-ring located on the bottom of the UE Boom 2, the opposite end of the power button.
    • Remove by twisting in a counter-clockwise motion.
  2. UE BOOM 2 Micro-USB Port Replacement: step 2, image 1 of 2 UE BOOM 2 Micro-USB Port Replacement: step 2, image 2 of 2
    • After the D-ring has been removed, the rubber port cover can be removed.
  3. UE BOOM 2 Micro-USB Port Replacement: step 3, image 1 of 3 UE BOOM 2 Micro-USB Port Replacement: step 3, image 2 of 3 UE BOOM 2 Micro-USB Port Replacement: step 3, image 3 of 3
    • Remove the rubber stripping using a metal spudger.
    • Work around the edge of the rubber stripping slowly prying up the edge.
  4. UE BOOM 2 Micro-USB Port Replacement: step 4, image 1 of 1
    • Continue removing the rubber stripping down the side.
  5. UE BOOM 2 Micro-USB Port Replacement: step 5, image 1 of 3 UE BOOM 2 Micro-USB Port Replacement: step 5, image 2 of 3 UE BOOM 2 Micro-USB Port Replacement: step 5, image 3 of 3
    • On the bottom, unscrew the four 15mm Phillips Head #2 screws, using the Phillips head #2 bit (labeled PH2 in the Pro Tech Toolkit).
    • Pry up at the location marked, and remove the plastic end cap.
    • The white plastic section houses the USB micro B, and must be replaced as a whole.
8 other people completed this guide.
Alex Bahm
2,311 Reputation
6 Guides authored
Cal Poly, Team S12-G5, Banghart Winter 2018 Member of Cal Poly, Team S12-G5, Banghart Winter 2018
CPSU-BANGHART-W18S12G5
2 Members
15 Guides authored
6 Comments
Hi,
Do you know where to buy this part?
Thanks!
cpgoga - Reply
Hello,
I am also looking to find where to order this part? I have searched on ebay / internet with no luck.
KM
Roock Canada - Reply
i too am looking to find the replacement part
Liam Nicholls - Reply
Found a place you can replace the USB connector if you can do a bit of soldering/unsoldering.
https://www.joesge.com/products/micro-us...
Roger Burke - Reply
Anyone have the part number to convert it to a USB type c instead of A?
vdub_corrado - Reply
Past 24 Hours: 8
Past 7 Days: 36
Past 30 Days: 99
All Time: 9,793
