Wintec Filemate Clear 7" Front Screen Replacement
  1. Wintec Filemate Clear 7" Front Screen Replacement, Remove the Backplate: step 1, image 1 of 1
    • Locate the four corners of the backplate.
  2. Wintec Filemate Clear 7" Front Screen Replacement: step 2, image 1 of 2 Wintec Filemate Clear 7" Front Screen Replacement: step 2, image 2 of 2
    • Pry off the backplate by inserting a spudger or plastic opening tool into each corner and popping them open.
  3. Wintec Filemate Clear 7" Front Screen Replacement, Remove the Battery: step 3, image 1 of 1
    • Un-stick the battery from the motherboard assembly with the plastic opening tool.
  4. Wintec Filemate Clear 7" Front Screen Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Desolder the battery wires from the motherboard.
    • The tweezers pictured point to the two solder joints.
  5. Wintec Filemate Clear 7" Front Screen Replacement: step 5, image 1 of 1
    • Fully remove the battery from the device.
  6. Careful: steps 6-10 are sourced from a guide that's marked as in-progress.
    Wintec Filemate Clear 7" Front Screen Replacement, Motherboard: step 6, image 1 of 1
    • Locate each of the motherboard's 4 mm screws.
  7. Wintec Filemate Clear 7" Front Screen Replacement, Unscrewing Everything: step 7, image 1 of 3 Wintec Filemate Clear 7" Front Screen Replacement, Unscrewing Everything: step 7, image 2 of 3 Wintec Filemate Clear 7" Front Screen Replacement, Unscrewing Everything: step 7, image 3 of 3
    • Remove each of the four 4 mm screws from the motherboard pictured to the left.
    • Use a Phillips #00 precision screwdriver.
  8. Wintec Filemate Clear 7" Front Screen Replacement, Detach the Motherboard: step 8, image 1 of 2 Wintec Filemate Clear 7" Front Screen Replacement, Detach the Motherboard: step 8, image 2 of 2
    • Use the spudger to pry the instrument array from its plastic housing.
  9. Wintec Filemate Clear 7" Front Screen Replacement: step 9, image 1 of 1
    • Slowly slide the spudger underneath the adhesive tape to un-sitck it.
    • Be careful not to harm the array of wires leading to this tape.
  10. Wintec Filemate Clear 7" Front Screen Replacement: step 10, image 1 of 1
    Buy
    • De-tatch the motherboard output wires from the screen using the tweezers.
  11. Wintec Filemate Clear 7" Front Screen Replacement, Front Screen: step 11, image 1 of 1
    • Locate the front screen's screws.
  12. Wintec Filemate Clear 7" Front Screen Replacement, Remove the Extra Screws: step 12, image 1 of 2 Wintec Filemate Clear 7" Front Screen Replacement, Remove the Extra Screws: step 12, image 2 of 2
    • There are two additional 4 mm screws holding the front screen.
    • Use the Phillips #00 screwdriver to remove the screws (pictured to the left).
  13. Wintec Filemate Clear 7" Front Screen Replacement: step 13, image 1 of 1
    • Fully remove the front screen from its plastic cover.
Nicholas Ferraro
431 Reputation
6 Guides authored
USF Tampa, Team 19-6, Blackwell Spring 2014 Member of USF Tampa, Team 19-6, Blackwell Spring 2014
USFT-BLACKWELL-S14S19G6
3 Members
11 Guides authored
One Comment
Hi, have a Filemate tablet and the front is broke . So is the Front and Digitizer the same thing? Thank you Brenda L Glidewell
Brenda L Glidewell - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 157
