Xelio P900A-BK Battery Replacement
Marcus Nelson
Marcus Nelson and 4 other contributors
Last updated on July 11, 2018
7 - 10 minutes
Difficult
Slice and Dice
Introduction
Go to step 1
Use this guide to remove and replace a dead battery in the Xelio P900A-BK tablet.
Tools
Show more…
  1. Xelio P900A-BK Battery Replacement, Battery: step 1, image 1 of 1
    • Using a #00 Phillips head screwdriver, remove the two 5.4mm bottom screws.
  2. Xelio P900A-BK Battery Replacement: step 2, image 1 of 2 Xelio P900A-BK Battery Replacement: step 2, image 2 of 2
    • Insert a plastic opening tool between the screen and the rear case and gently work your way around the tablet.
  3. Xelio P900A-BK Battery Replacement: step 3, image 1 of 1
    • Using the plastic opening tool or your fingers, gently pry the pieces of the tablet apart. You will hear the plastic latches pop free.
  4. Xelio P900A-BK Battery Replacement: step 4, image 1 of 3 Xelio P900A-BK Battery Replacement: step 4, image 2 of 3 Xelio P900A-BK Battery Replacement: step 4, image 3 of 3
  5. Xelio P900A-BK Battery Replacement: step 5, image 1 of 2 Xelio P900A-BK Battery Replacement: step 5, image 2 of 2
    • Carefully insert the flat end of a nylon spudger under the battery, and pry the battery up and away from the tablet casing.
    • A small amount of heat may be required to safely remove the battery from the adhesive underneath. Use an iOpener or heat gun to soften the adhesive.
    • Do not bend or puncture the battery.
    • Place the new battery in the same place as the old one, making sure it is oriented the same way as the old one was.
2 other people completed this guide.
Marcus Nelson
307 Reputation
3 Guides authored
One Comment
I am attempting to fix one of these for a friend, but I can't seem to get it open! Does it require a significant amount of force? I am afraid I will break it...
skatermonkey06 - Reply
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 6
All Time: 370
