Help
Power Mac G5 Processor and Cooling Unit Replacement
Editing Step 5 —
Notice: You are editing a prerequisite guide. Any changes you make will affect the guide that includes this step.
Step Type:
Drag to rearrange
NOTE: Here are the standoffs without the cooling unit installed to make it easier to understand where the screws are located. Remove the bottom 2 standoffs so it is easier to remove the power supply.
Check the pin connections for any damage. All the pins highlighted in yellow should appear straight up and not appear bent. DON'T TOUCH THE PINS. A bent pin will result in your computer not powering on.
