Help
Dell OptiPlex GX260 Power Supply Replacement
Editing Step 2 —
Step Type:
Drag to rearrange
Remove the two Phillip screws holding the power supply into the the case and lift the power supply out.
When installing a new power supply ensure that the voltage selector is correctly set before you connect the mains cable.
Incorrect voltage settings will damage the power supply and may also cause other components to be damaged.
