Help
Canon PowerShot S100 Outer Case Replacement
Editing Step 3 —
Notice: You are now editing a prerequisite to the guide you were just viewing. Any changes you make will affect all 4 guides that include this step.
Step Type:
Drag to rearrange
Turn the camera so that the lens is facing you.
Do not pull the front panel off without removing the ribbon cable first.
Slowly lift the front panel from the camera.
The ribbon cable is connecting the front panel to the camera. Using the tweezers, gently pull the ribbon cable out of its socket.
A spudger may also be used to remove the ribbon cable.
Remove the rubber guard that rests on top of the lens.
