Help
MacBook Pro 15" Unibody Early 2011 Upper Case Replacement
Editing Step 2 —
Notice: You are editing a prerequisite guide. Any changes you make will affect all 2 guides that include this step.
Step Type:
Drag to rearrange
Carefully peel the battery warning label off the upper case between the battery and the optical drive to reveal an additional Tri-point screw.
Remove the last 7.5 mm ( 7.2 mm ) Tri-point screw securing the battery to the upper case.
Do not remove the label from the battery.
