iRobot Roomba 650 Side Brush Motor Replacement
Charles Ward
Charles Ward and 4 other contributors
Last updated on June 17, 2015
10 minutes
Moderate
Introduction
Go to step 1
This component is what drives the side brush in action. When the motor is damaged, replacement is needed in order for the side brush to work properly. The side brush motor is housed underneath the bottom panel inside a gearbox.
Tools
  1. iRobot Roomba 650 Side Brush Motor Replacement, Removing the Side Brush: step 1, image 1 of 2 iRobot Roomba 650 Side Brush Motor Replacement, Removing the Side Brush: step 1, image 2 of 2
    • With the Roomba upside down and turned off, use the Phillip's 02 screwdriver to remove the one 3.5 mm screw from the center of the side-brush.
    • Set the screw aside and pull the brush out.
  2. iRobot Roomba 650 Side Brush Motor Replacement, Bottom Panel Removal: step 2, image 1 of 2 iRobot Roomba 650 Side Brush Motor Replacement, Bottom Panel Removal: step 2, image 2 of 2
    • Unscrew the four screws that hold the bottom panel using the Phillips 02 screwdriver.
    • The screws will not come out of the bottom panel. They were designed to become loose but not be removed. This prevents you from losing them, and prevents the Roomba from sucking them up if they came out during cleaning.
    • Once you are sure that all the screws have been loosened as much as possible, then lift the bottom panel up off the Roomba.
  3. iRobot Roomba 650 Side Brush Motor Replacement, Side Brush Motor: step 3, image 1 of 2 iRobot Roomba 650 Side Brush Motor Replacement, Side Brush Motor: step 3, image 2 of 2
    • Locate and loosen the two small screws fastened to the motor housing with the Phillip's 00 Screwdriver. Like the bottom panel screws, these will not come out completely.
  4. iRobot Roomba 650 Side Brush Motor Replacement, Gear Box Cover: step 4, image 1 of 3 iRobot Roomba 650 Side Brush Motor Replacement, Gear Box Cover: step 4, image 2 of 3 iRobot Roomba 650 Side Brush Motor Replacement, Gear Box Cover: step 4, image 3 of 3
    • Remove the screw on top of the housing. The small plastic piece should come right off.
    • Carefully pry open the gear box by inserting a flat head screwdriver in the slot on the end of the box. This might be difficult and require some wiggling of the screwdriver.
    • The cover should come right off.
  5. iRobot Roomba 650 Side Brush Motor Replacement, Motor Removal: step 5, image 1 of 2 iRobot Roomba 650 Side Brush Motor Replacement, Motor Removal: step 5, image 2 of 2
    • Locate and loosen the two screws inside the gearbox with the Phillips 00 Screwdriver. The motor should come right out the bottom.
5 other people completed this guide.
Charles Ward
1,011 Reputation
3 Guides authored
Cal Poly, Team 19-7, Maness Winter 2015 Member of Cal Poly, Team 19-7, Maness Winter 2015
CPSU-MANESS-W15S19G7
4 Members
6 Guides authored
6 Comments
In step 4, the screw on top of the housing has an unusual head. It's similar to a Phillips screw, but it only has 3 grooves. A small flat blade screw driver can unscrew it.
When you pry off the cover of the gear box, some gears may pop out, so do this on a work surface where they won't get lost.
You may find that the brush has stopped rotating because the inside of the gear box is full of lint.
Stephen Tashiro - Reply
Side brush motor works hooked to7,4v battery will not work in its socket pocket. tested voltage at springs only getting 5.3 v is this low voltage issue from Roomba or voltage ok , Springs are fine in sockets.
Shawn Hunter - Reply
Any idea where to get the main drive GEAR my motor is fine but the main gear is missing teeth
Joe Escuage - Reply
They can be found at Amazon/Ebay, but they ain’t cheap.
duder -
Those gears look like a pretty standard set, but need some kind of spec or part # to replace
Matt Weatherford - Reply
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 28
All Time: 10,277
