This teardown is not a repair guide. To repair your NEC PC-FX, use our service manual.
  1. NEC PC-FX Teardown, Remove Side Panels: step 1, image 1 of 1
    • Remove the four T10 screws located underneath the console. These hold the left and right side panels in place.
    • After removing these screws, you should easily be able to slide off the left and right panels.
  2. NEC PC-FX Teardown, Remove the Front Plate: step 2, image 1 of 1
    • Remove the front panel attached by three clips on each side. The top two clips on the left are encircled in the picture.
  3. NEC PC-FX Teardown, Remove the Top Panel: step 3, image 1 of 2 NEC PC-FX Teardown, Remove the Top Panel: step 3, image 2 of 2
    • With the front panel out, lift the top panel that is attached by three clips on each side. Be aware that the top panel is attached to the daughterboard via the lid sensor connector (second picture), so do not pull it away immediately.
    • Remove the lid sensor connector in order to fully free up the top panel.
  4. NEC PC-FX Teardown, Remove the Rear Panel: step 4, image 1 of 2 NEC PC-FX Teardown, Remove the Rear Panel: step 4, image 2 of 2
    • Now remove the rear panel. First, unscrew the two Philips screws in the rear.
    • Remember that when reassembling the unit, you will need to affix the panels in the exact reverse order (Rear, Top, then Front).
    • With the rear screws removed, remove the rear panel attached by three clips on each side. The second picture shows the two lower clips on the left side (viewing from the front).
  5. NEC PC-FX Teardown, Remove the CD Drive: step 5, image 1 of 3 NEC PC-FX Teardown, Remove the CD Drive: step 5, image 2 of 3 NEC PC-FX Teardown, Remove the CD Drive: step 5, image 3 of 3
    • Now turn your attention to the CD drive. Lift up the tabs holding the drive ribbon connector at the left and the power connector at the right (if you haven't already).
    • Unscrew the four small Philips screws on each post holding up the drive (encircled in the second pictur). You may now lift up the drive and remove the springs on each post underneath.
    • There will be a transparent plastic sheet holding the ribbon connector in place. I strongly suggest totally removing this, as this will make plugging back the drive much easier.
    • The third picture shows the remaining adhesive after from removing the clear plastic sheet.
  6. NEC PC-FX Teardown, Remove the Power and Daughter Board Screws: step 6, image 1 of 1
    • Remove the 8 philip screws encircled. For the lower leftmost screw, you will need to move the power cable out of the way. The lower rightmost screw will also be holding in a ground cable.
    • Remove the daughterboard shielding (the big one on the right of the Power Board) after.
  7. NEC PC-FX Teardown, Remove the Power Board: step 7, image 1 of 2 NEC PC-FX Teardown, Remove the Power Board: step 7, image 2 of 2
    • Unplug the 4-pin power connector from the daughterboard to the powerboard (with yellow wire). Do the same with the 5-pin power connector from the motherboard (with red wire).
    • After this you may remove the power board. You will have to pull the whole power cable from the inside as shown in the second picture.
  8. NEC PC-FX Teardown, Remove the Daughter Board: step 8, image 1 of 1
    • Remove the main ribbon cable from the daughterboard.
    • The daughterboard may then be removed since nothing else will be affixing it to the unit.
  9. NEC PC-FX Teardown, Remove the Mother Board Screws: step 9, image 1 of 1
    • Remove the four corner screws, and the three long screws in the middle of the motherboard.
  10. NEC PC-FX Teardown, Remove the Motherboard: step 10, image 1 of 2 NEC PC-FX Teardown, Remove the Motherboard: step 10, image 2 of 2
    • The trickiest part - remove the main motherboard. To do this, you will have to flex the top part of the plastic frame up while lifting the upper part of the motherboard towards you.
    • This may require some fiddling, so check from time to time if there is no frame plastic blocking the top part of the motherboard when you lift it up. If you have trouble, you almost certainly just need to flex up the top area of the plastic frame a bit more.
  11. NEC PC-FX Teardown, Remove the Expansion Port Bays: step 11, image 1 of 1
    • With the motherboard liberated, simple unsnap the three encircled clips of the expansion port bays. You are now done with the teardown at this point.
  12. NEC PC-FX Teardown, Completed Teardown: step 12, image 1 of 2 NEC PC-FX Teardown, Completed Teardown: step 12, image 2 of 2
    • This completes the teardown. Reassembly will require reversing the teardown procedure, but please see my notes on the next step on some important reassembly tips to keep in mind.
  13. NEC PC-FX Teardown, Reassembly Tips: step 13, image 1 of 1
    • When reassembling any of the three expansion port bays, make sure that the lower "lip" fits BETWEEN the PCB and shielding underneath. Failure to do so may not allow the Rear, Top and Front outer panels to close properly.
    • When putting in the motherboard back, insert it the opposite way you took it out. Slide in the PCB bottom side first, then flex up the top frame area while pushing down the topside of the PCB.
    • After reinserting the motherboard, check to make sure that all three three expansion port pieces are snapped correctly into place within the bare PC-FX plastic frame.
    • Again, remember that when reassembling the unit, you will need to affix the panels in the exact reverse order you removed them in this guide. (Rear, Top, then Front). This is because they are interlocking.
Paul Prantilla
217 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 60
All Time: 2,937
