Help
NEC PC-FX Teardown
Editing Step 4 —
Step Type:
Drag to rearrange
Now remove the rear panel. First, unscrew the two Philips screws in the rear.
Remember that when reassembling the unit, you will need to affix the panels in the exact reverse order (Rear, Top, then Front).
With the rear screws removed, remove the rear panel attached by three clips on each side. The second picture shows the two lower clips on the left side (viewing from the front).
