PlayStation 3 CECHH01 Teardown
  1. PlayStation 3 CECHH01 Teardown, Remove HDD: step 1, image 1 of 3 PlayStation 3 CECHH01 Teardown, Remove HDD: step 1, image 2 of 3 PlayStation 3 CECHH01 Teardown, Remove HDD: step 1, image 3 of 3
    • Using fingernail, or spudger, remove the cover.
    • Remove PH1 screw
    • Pull HDD out.
  2. PlayStation 3 CECHH01 Teardown, Remove security screw: step 2, image 1 of 2 PlayStation 3 CECHH01 Teardown, Remove security screw: step 2, image 2 of 2
    • Remove sticker an underlying rubber tab
    • Remove the T8 security screw (T10 sometimes)
    • Pull cover towards you to remove
  3. PlayStation 3 CECHH01 Teardown: step 3, image 1 of 2 PlayStation 3 CECHH01 Teardown: step 3, image 2 of 2
    • Remove the 6 long medium screws
    • Remove the medium medium screw. This screw is conveniently marked with an S if you forget what goes where.
    • The blueray drive is NOT screwed down. Do not tip the console!
    • Use a finger to press the tab next to the medium length screw and lift. The case pivots on the front.
    • When putting back together, place the front edge and rotate back. The screws will pop everything back in place.
  4. PlayStation 3 CECHH01 Teardown, Remove Blueray drive: step 4, image 1 of 3 PlayStation 3 CECHH01 Teardown, Remove Blueray drive: step 4, image 2 of 3 PlayStation 3 CECHH01 Teardown, Remove Blueray drive: step 4, image 3 of 3
    • Flip the Blu-Ray drive over and lift the black tab to remove the ribbon cable.
    • Disconnect the 4 pin cable attached to the Blu-Ray drive.
  5. PlayStation 3 CECHH01 Teardown, Remove power supply screws: step 5, image 1 of 3 PlayStation 3 CECHH01 Teardown, Remove power supply screws: step 5, image 2 of 3 PlayStation 3 CECHH01 Teardown, Remove power supply screws: step 5, image 3 of 3
    • Remove M screw
    • Remove medium medium screws
    • Remove long M screws
    • When putting back together, the fine thread screws are marked with M.
  6. PlayStation 3 CECHH01 Teardown, Unhook power supply: step 6, image 1 of 2 PlayStation 3 CECHH01 Teardown, Unhook power supply: step 6, image 2 of 2
    • Push down on tab and pull straight out
    • Pull straight out
  7. PlayStation 3 CECHH01 Teardown, Remove power supply: step 7, image 1 of 1
    • Do not use a metal spudger! There are exposed prongs that may short and shock you. I did not know this when I did it.
    • Using something non-conductive, lift this corner up to make removal easier.
    • Pull straight up to remove the power supply.
  8. PlayStation 3 CECHH01 Teardown, Unscrew the board brace: step 8, image 1 of 3 PlayStation 3 CECHH01 Teardown, Unscrew the board brace: step 8, image 2 of 3 PlayStation 3 CECHH01 Teardown, Unscrew the board brace: step 8, image 3 of 3
    • Remove the short medium screws
    • Remove the ground screw
    • Remove the heatsink screws and braces
    • Lift the front to remove
    • Do this slowly. The heatsinks are not screwed down and you may damage the fins if you use too much force.
    • This is the second time I've taken this apart. That's why there is no thermal paste on the chips. They do put paste on there. Too much in my opinion.
    • When putting back together, all the screw places are marked. If the hole doesn't have a marker, don't put a screw in it.
  9. PlayStation 3 CECHH01 Teardown, Remove the shields: step 9, image 1 of 2 PlayStation 3 CECHH01 Teardown, Remove the shields: step 9, image 2 of 2
    • Unscrew the M screws and unplug the board battery. Your PS3 now does not know the date and time.
    • I messed up when I put it back together. The shield goes under the top half of the HDD cage.
    • Lift this side of the HDD cage and wiggle it. The pins can be tricky.
    • Remove the shield over the USB and WiFi controller
    • Remove the USB and WiFi controller. It lifts straight up. Remove the white tape.
    • Lift from this side to remove the motherboard shield.
    • The motherboard lifts right out
  10. PlayStation 3 CECHH01 Teardown: step 10, image 1 of 2 PlayStation 3 CECHH01 Teardown: step 10, image 2 of 2
    • Ok, I forgot to take a picture before unscrewing the bottom. There are 4 small medium screws.
    • The back plate lifts up
    • The fan and cover lifts straight up
    • The heatsinks are not screwed down and lift right out
  11. PlayStation 3 CECHH01 Teardown, Done: step 11, image 1 of 2 PlayStation 3 CECHH01 Teardown, Done: step 11, image 2 of 2
    • Insert wisdom here.
Finish Line
77 other people completed this guide.
knyrii
2,450 Reputation
1 Guide authored
27 Comments
I have this exact same ps3 model and I took it apart to clean it and now the controller won't sync. I press the PS button and all 4 lights blink rapidly (faster than when 1 blinks when it's charging) for about 30 secs and then turn off. I have tried to sync it a couple diff ways with the same result.
Jeff - Reply
The ribbon cable in image 2 of step 6 may be loose.
knyrii -
My ps3 Fat bluetooth not working i am changing thE bluetooth plate but not working pls help
harpreet singh - Reply
Only a few things I can think of:
Replacement module is bad
Replacement module is the wrong version
Something is interfering with the bluetooth signal
knyrii -
My PS3 keeps shutting down when trying to load a game...sometimes it goes but some other times not...
Any help?
Thanks in advance
Ana Teixeira - Reply
Past 24 Hours: 41
Past 7 Days: 350
Past 30 Days: 1,616
All Time: 145,465
