This teardown is not a repair guide. To repair your Sony Xperia Z3 Dual, use our service manual.
  1. Sony Xperia Z3 Dual Teardown, Sony Xperia Z3 Dual Teardown: step 1, image 1 of 3 Sony Xperia Z3 Dual Teardown, Sony Xperia Z3 Dual Teardown: step 1, image 2 of 3 Sony Xperia Z3 Dual Teardown, Sony Xperia Z3 Dual Teardown: step 1, image 3 of 3
    • Remove two SIM card trays.
    • Heat the back cover to soften the adhesive sticker.
    • Place the suction cup and to open a gap from top side.
  2. Sony Xperia Z3 Dual Teardown: step 2, image 1 of 3 Sony Xperia Z3 Dual Teardown: step 2, image 2 of 3 Sony Xperia Z3 Dual Teardown: step 2, image 3 of 3
    • Insert the guitar pick into the opening gap.
    • Slide the guitar pick to cut the adhesive sticker. Attention: when deal with the left side, the guitar pick would better go as the direction of the mark.
  3. Sony Xperia Z3 Dual Teardown: step 3, image 1 of 2 Sony Xperia Z3 Dual Teardown: step 3, image 2 of 2
    • Release battery connector.
    • Free the fastening sticker.
  4. Sony Xperia Z3 Dual Teardown: step 4, image 1 of 2 Sony Xperia Z3 Dual Teardown: step 4, image 2 of 2
    • Pry up and remove the battery.
    • 3100mAh battery.
  5. Sony Xperia Z3 Dual Teardown: step 5, image 1 of 1
    • Twist off screws.
  6. Sony Xperia Z3 Dual Teardown: step 6, image 1 of 3 Sony Xperia Z3 Dual Teardown: step 6, image 2 of 3 Sony Xperia Z3 Dual Teardown: step 6, image 3 of 3
    • Remove three pieces of securing bracket.
  7. Sony Xperia Z3 Dual Teardown: step 7, image 1 of 3 Sony Xperia Z3 Dual Teardown: step 7, image 2 of 3 Sony Xperia Z3 Dual Teardown: step 7, image 3 of 3
    • Release all the connectors.
    • Remove sim tray before removing motherboard.
    • Remove the motherboard carefully.
  8. Sony Xperia Z3 Dual Teardown: step 8, image 1 of 3 Sony Xperia Z3 Dual Teardown: step 8, image 2 of 3 Sony Xperia Z3 Dual Teardown: step 8, image 3 of 3
    • That's Sony Xperia Z3 Dual motherboard.
  9. Sony Xperia Z3 Dual Teardown: step 9, image 1 of 3 Sony Xperia Z3 Dual Teardown: step 9, image 2 of 3 Sony Xperia Z3 Dual Teardown: step 9, image 3 of 3
    • Remove front camera and rear camera.
  10. Sony Xperia Z3 Dual Teardown: step 10, image 1 of 3 Sony Xperia Z3 Dual Teardown: step 10, image 2 of 3 Sony Xperia Z3 Dual Teardown: step 10, image 3 of 3
    • Remove that blocker beside the earpiece speaker at first.
    • And then you can pry up the earpiece speaker and remove it.
  11. Sony Xperia Z3 Dual Teardown: step 11, image 1 of 1
    • Remove transparent securing cover beside of earphone jack.
  12. Sony Xperia Z3 Dual Teardown: step 12, image 1 of 3 Sony Xperia Z3 Dual Teardown: step 12, image 2 of 3 Sony Xperia Z3 Dual Teardown: step 12, image 3 of 3
    • Pry to turn the flex cover on the earphone jack. But it's a part of the earphone jack assembly.
    • Cut the adhesive sticker between the earphone jack and midframe and remove the assembly.
  13. Sony Xperia Z3 Dual Teardown: step 13, image 1 of 1
    • That's antenna signal flex.
  14. Sony Xperia Z3 Dual Teardown: step 14, image 1 of 3 Sony Xperia Z3 Dual Teardown: step 14, image 2 of 3 Sony Xperia Z3 Dual Teardown: step 14, image 3 of 3
    • Twist off screws.
    • Release connectors.
    • Remove vibrator securing bracket.
  15. Sony Xperia Z3 Dual Teardown: step 15, image 1 of 3 Sony Xperia Z3 Dual Teardown: step 15, image 2 of 3 Sony Xperia Z3 Dual Teardown: step 15, image 3 of 3
    • Remove loudspeaker assembly securing bracket. And there is no any adhesive.
    • Pry up and remove the loudspeaker assembly. No adhesive, too.
  16. Sony Xperia Z3 Dual Teardown: step 16, image 1 of 1
    • Done.
Sophia
43,810 Reputation
62 Guides authored
9 Comments
Can you put it back together?
zarixevolve - Reply
I dropped mine so I just want to take the battery out is it possibly to take it and then put it back in
zarixevolve - Reply
hi.after changing my xperia z3 dual lcd 3 times.i hade a fluctuating and very week 3g and 4g signal.plz tell me where is the antenna located.i know that there is a flex and a board and antenna cover.what should i change.thanx
zein hamza - Reply
That's not a complete teardown. I would like to see the onboard chips and info's.
emmacorsa17 - Reply
Where can i buy the Sony Xperia Z3 plus Dual motherboard ?
I really need it.
Kwar Kwar - Reply
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 23
All Time: 39,259
