Back Cover
1 Answer 0 Score |
There dust on camera sensor, cannot get rid of it.. |
1 Answer 0 Score |
Screen is not turning on despite replacing the LCD, Main flex cable |
1 Answer 0 Score |
Loudspeaker Antenna low volume |
1 Answer 0 Score |
Why is the device booting itself every 2-3 seconds? |
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
(D6633)
Background and Identification
Announced in September 2014, the Sony Xperia Z3 Dual is part of Sony’s flagship Xperia line of Android smartphones and is a dual sim variant of the Xperia Z3. With a 5.2 inch touchscreen display, the Z3 Dual has a large display with an IPS panel that is bright with vivid colors. Moreover, the Sony Xperia Z3 Dual has a Li-ion 3100 mAh battery giving users a long run time.
Compared to the previous Xperia Z phone, the Z3 Dual does not deviate much in its design. The glass-covered front and rear as well as the aluminum band that holds the phone together are all carried over. However, the Z3’s profile is smaller, slimmer, and lighter than the Z2. Also, the Z3 Dual has rounded edges allowing for a more comfortable grip.
Technical Specifications
- Display: 5.2 inches
- Touchscreen: Yes
- Resolution: 1080 x 1920 pixels
- Pixels per inch (PPI): 424
- Processor: 2.5 GHz quad-core
- Processor Make: Qualcomm Snapdragon
- RAM: 3GB
- Internal Storage: 16GB
- Expandable Storage: up to 128 GB via microSD
- Rear Camera: 20.7-megapixel, LED,
- Front Camera: 2.2-megapixel
- Battery: Li-ion 3100 mAh
- Operating System: Android 4.4
- Connectivity:
- Wi-Fi: Yes
- Wi-Fi standards supported: 802.11 a/b/g/n/ac
- GPS: Yes
- Bluetooth: Yes, v 4.00
- NFC: Yes
- Infrared: No
- USB OTG: No
- Headphones: 3.5mm
- FM: Yes
- Number of SIMs: 2
- Wi-Fi Direct: Yes
- Mobile High-Definition Link (MHL): No
- SIM 1:
- SIM Type: Nano-SIM
- GSM/CDMA: GSM
- 3G: Yes
- 4G/ LTE: Yes
- SIM 2:
- GSM/CDMA: GSM
- 3G: Yes
- 4G/ LTE: No
