Introduction
Go to step 1A quick and easy teardown/disassembly guide for the ZEN V Creative Media Player.
Here we have Creative's ZEN V Media Player.
The Navigator Stick
The Play/Pause Button
The Back Button
The LCD
USB 2.0 Charging Port
Headphone Jack
Line In Jack
Start by taking a pointy metal spudger and insert it on the bottom edge of the player
Slide it along, prying up until a gap forms
Proceed to insert and slide the tool along the left and right side of the device, until the plastic piece with the buttons comes free.
Half of the covering plastic should be off now
Gap between plastics
Put down your spudger and pick up a Phillips #000 Screwdriver
Remove the two screws on the logic board
Screws
Remove Volume control button by pulling it up off the board
Pull up board from bottom of player
Gently wiggle the logic board out of the casing. Be careful because it is connected to a battery underneath it
Battery
These all are various components that can be removed with a soldering iron
USB 2.0 Port has 4 pads and 5 pins attaching it to the logic board
Various Switches- 4 pads each. From the (Bottom left), Volume up, Volume Down, Mute?, (Top Left), Power on/Hold, Reset
Line In Jack 4 pads
Headphone Jack 4 pads
Play/Pause Button 2 pads and Back Button 2 pads
LCD connector and Navigtor button
