Help
Gateway ID47H07u Teardown
Editing Step 9 —
Step Type:
Drag to rearrange
Here we see the front bezel after it has been removed from the screen.
The second image is of the LED Backpanel. The hinges are mount directly to this and there are no screen mounts in between the hinges and backpanel. You might also note that the webcam and wireless cables are not mounted to this.
The third image is of the screen itself from the backside. Here we see the wireless cables and webcam.
The screen itself is not very common among laptops and will require some extra searching to locate a proper replacement if it is needed.
I am providing the model number of the screen I pulled in case you want to order the screen in advance to replacing it. Part #: LK140080101
