Help
HP Compaq nx7010 Business Notebook Teardown
Editing Step 17 —
Step Type:
Drag to rearrange
The display enclosure
It is actually quite easy to do a DIY screen replacement as there is no glass or adhesive to deal with but there are tabs that snap everything together
Removing the 6 screws allows you carefully remove the bezel by carefully undoing the tabs with a flathead screwdriver.
I recomend using something made from soft plastic to undo the tabs as the plastic bezel and metal back panel damage easily.
The hinges simply screw on and off
