Help
Lenovo ThinkPad T61p Teardown
Editing Step 8 —
Step Type:
Drag to rearrange
Remove the visible screws holding down the LCD panel frame and the inverter and bluetooth circuit boards located below the LCD. The metal assembly will come out from the plastic backing.
The LCD housing is attached to the plastic back panel on the 4 corners, including on the hinges. Remove these screws.
Now would be a good time to protect your screen with bubble wrap or foam bordered by tape. Green X is for visibility and warning.
