Help
Amazon Echo Teardown
Editing Step 11 —
Step Type:
Drag to rearrange
Now for the fun part!
Speakers are all well and good, but Alexa's true mouthpiece is the swivel-top volume control and light ring. Alexa acknowledges a voice command by changing the LEDs pointing toward you from blue to...lighter blue.
The volume dial contains the user-interactive bits: the top portion spins freely, using a greased-up gear to turn an encoder...
...which you can also control via voice command!
Pro tip: take the Echo out of its protective plastic covering before attempting volume level 10.
