Help
MacBook Pro 15" Unibody Teardown
Editing Step 26 —
Step Type:
Drag to rearrange
Removing the Airport card.
Disconnect the antenna connector and the data cable.
Remove the two screws.
The Bluetooth cable disappears into the display, and our sources tell us that it's sandwiched between the glass and the metal case. This means that if your Bluetooth goes out, you may have to replace the entire display!
