Help
Nintendo Wii Teardown
Editing Step 7 —
Notice: You are editing a prerequisite guide. Any changes you make will affect the guide that includes this step.
Step Type:
Drag to rearrange
Careful! If you don't remove the feet and the screws underneath before you try to pull off the front panel, the tab can split!
Once all screws are removed, you should be able to pull off the front drive panel.
The wire connecting the front panel (green squares in the third image) can be pulled out gently by hand or with the help of a spudger.
