Help
Microsoft Surface Keyboard (WS2-00025) Teardown
Editing Step 8 —
Step Type:
Drag to rearrange
It would be quite underhanded to put screws under the keys. Luckily that is not the case here.
To remove a key, wedge a plastic spudger under the key from the top most edge. Apply a bit of downward pressure on the spudger to lift the key. The key should make popping sounds and unlatch from the metal clips underneath the key that hold it to the keyboard frame.
