Pre-Lit Christmas Tree Will Not Light Up
Kristen Gismondi and 1 contributor
Last updated on
First, for sanity sake, make sure the tree is plugged in to a working outlet. Sounds silly, but it doesn't hurt to check.
Causes
If your pre-lit tree has multiple light strands, ensure they are all plugged into one another.
2
Find the fuse compartment in the male end of the faulty string of lights. Slide open the latch and pop out the fuse. Replace with a new fuse. Some pre-lit Christmas trees are sold with extra fuses.
To identify a broken fuse, look for a break in the wire or a dark smudge located inside of the fuse. Either of these indicate the fuse has blown. You can also use a multimeter to confirm that the fuse has blown.
Pre-Lit Christmas Tree Incandescent Light Fuse Replacement
3
If the bulb is damaged, burnt out, or missing you will need to replace it. Some pre-lit Christmas trees are sold with extra bulbs. Make sure the new bulb is seated firmly in the socket.
Tip: While removing bulbs check for corrosion or blockages in the sockets on the strand.
4
If replacing the first few bulbs with known-good bulbs doesn't work, check that there is a good connection between socket and bulb. Remove grime and other blockages with tweezers or a toothpick, and clean up corrosion(rust) with contact cleaner or isopropyl alcohol.
5
Tip: Tools like the LightKeeper Pro can help bridge broken circuits and further diagnose and fix problems. The video below demonstrates the use of the Quick Fix function.
View statistics:
Past 24 Hours:
0
Past 7 Days:
0
Past 30 Days:
13
All Time:
938
