Dell XPS Series Troubleshooting: Fix Common Problems
The first step towards a working Dell XPS Series is identifying the problem. Select one of our preferred guides below to diagnose and solve Dell XPS Series common issues.
Dell XPS Black Screen
Does your Dell XPS have a black screen? This problem page will go over several common occurrences when it comes to a Dell XPS screen not turning on. The problem can be caused by either software or hardware causes, so read on to determine the right solution for you!
Dell XPS Not Charging
If your Dell XPS is not charging, this page aims to help you identify the causes and what to do to fix them.
Dell XPS Keyboard Not Working
If your Dell XPS keyboard is not working, this page aims to help you identify the causes and what to do to fix them.
Dell XPS Battery Draining Fast
If your Dell XPS battery is draining fast, this page aims to help you identify the causes and what to do to fix them.
Related Dell Laptop Problems
Dell Laptop Not Charging
If your Dell laptop is not charging, this page aims to help you identify the causes and what to do to fix them.
Dell Laptop Keyboard Not Working
If your Dell laptop keyboard is not working, this page aims to help you identify the causes and what to do to fix them.
Dell Laptop Battery Draining Fast
If your Dell laptop battery is draining fast, this page aims to help you identify the causes and what to do to fix them.
Dell Laptop Won't Turn On
If your Dell laptop won't turn on, isn't starting, or gets hung up on a startup screen, this page aims to help you identify the causes and how to fix them.
Dell Laptop Frozen
Is your laptop locking up or freezing? Are apps becoming non-responsive? Is your laptop stuck on the lock screen? Keep reading for some fixes!
Dell Laptop Keeps Restarting
Is your Dell laptop rebooting randomly or restarting over and over? Are you stuck in a boot loop and can't get out? Have a look at these solutions.
Dell Laptop Blue Screen
Is your Dell laptop crashing to a Blue Screen? Are you getting random restarts followed by a blue error message? This will need some detective work, but is definitely fixable!
Dell Laptop Running Slow
Is your Dell laptop struggling with simple tasks? Is it running as slow as molasses? Are apps non responsive, or your cursor keeps spinning? Try these tips to top out your speed!
Dell Laptop Black Screen
Does your Dell laptop have a black screen? Are you unable to get anything on your display? Can you only see black aside from a cursor? Have a look at these fixes!
Dell Laptop Overheating
Is your Dell laptop getting too hot? Is it uncomfortable to sit with your laptop in your lap? Is your fan spinning at full speed all the time? These fixes will cool you off in no time!
Didn't see your problem? The iFixit Community has answers.
Browse the most common questions asked by our members to see more solutions. Still no luck? You can always ask for help!
boys your help is necessary
Dell XPS 13 (9343/9350)
Replacement battery not detected
Battery not charging after replacement
Dell XPS 13 9380 (2019)
Change USB-c port
Replacing Qualcomm AX500 Killer Wifi
Dell XPS 15 9500
