Samsung Galaxy S20 Troubleshooting: Fix Common Problems
The first step towards a working Samsung Galaxy S20 is identifying the problem. Select one of our preferred guides below to diagnose and solve Samsung Galaxy S20 common issues.
Samsung Galaxy S20 Touchscreen Unresponsive
Fix all your unresponsive touchscreen woes with this diagnostic guide to up your touchscreen sensitivity and get you back to tapping.
Samsung Galaxy S20 Will Not Turn On
Solve any issues you may be having with your Samsung Galaxy S20 not turning on with this solution page full of common causes and how to fix them.
Samsung Galaxy S20 Black Screen
If the screen on your Samsung Galaxy S20 smartphone is failing to display images, is displaying a completely blank or black screen despite the phone being "on", is flickering, discolored, or is otherwise malfunctioning, use this handy solution page to solve your broken screen problems.
Samsung Galaxy S20 Camera Not Working
If you are experiencing problems with your Samsung Galaxy S20's camera(s), this solution page will help you identify and eliminate your problems.
Samsung Galaxy S20 Network Issues
If your Samsung Galaxy S20 won't connect to a mobile or WiFi network, use this troubleshooting page to get connected!
Related Samsung Phone Problems
Samsung Galaxy Phone Battery Draining Fast
Is your Galaxy phone draining battery quickly? Does a charge not last a full day or anymore? Do you find yourself needing to charge multiple times a day? Have a look at these solutions to optimize your battery life!
Samsung Galaxy Not Charging
Is your Samsung phone not accepting a charge? Is your charger good, but you can't get your phone to respond? Check out these fixes to get back in order!
Samsung Phone Lines on Screen
Is your Samsung Galaxy phone plagued with lines onscreen? Are green and purple lines covering the content you're trying to see? Take a look at this page to discover the cause.
Samsung Galaxy Phone Not Turning On
Is your Samsung Galaxy failing to power on? Are you getting no signs of life? Even if you've left it to charge all night? Well you're in the right place.
Samsung Galaxy Phone Black Screen
Is your Samsung phone on, but nothing is on the screen? Hearing system alerts, but all you can see is black? Check out these fixes!
Samsung Phone Moisture Detected in Charging Port
Is your Samsung phone warning that you’ve got liquid in the charge port? Is it blocking you from charging your phone? Keep your port dry and try these fixes!
Samsung Galaxy Frozen Screen
Is your Samsung Galaxy phone unresponsive? Is it frozen o on the lock screen or mid task? There are some easy fixes to get unstuck!
Samsung Galaxy Keeps Restarting
Is your Galaxy phone boot looping? Is it restarting unexpectedly, (or predictably). There are plenty of solutions to get you up and running.
Samsung Galaxy Camera Blurry
Does your camera consistently take blurry photos? Is it making a vibrating noise or has issues maintaining focus? Buckle up and give these solutions a go
Samsung Galaxy Overheating
Is your Samsung Galaxy getting too warm? Getting a warning on screen that your phone is hot? Can't get the warning to go away? Have a look at these ideas.
Samsung Galaxy No Sound
Is your Galaxy phone staying silent? Can't hear music or videos even with the volume at max? Missing calls because they seem to be silent? Get going again with these fixes!
Didn't see your problem? The iFixit Community has answers.
Browse the most common questions asked by our members to see more solutions. Still no luck? You can always ask for help!
Where can I find the Self-Repair Assistant app?
Samsung Galaxy S20
Phone responsive but black screen: Broken motherboard or display?
Samsung Galaxy S20
Battery percentage flashes on and off
Samsung Galaxy S20
Replaced the charging port now a few things don't work
Samsung Galaxy S20
Trying to reseal back glass
Samsung Galaxy S20
Can my s20 work without the display?
Samsung Galaxy S20
How to recover deleted photos from Samsung galaxy s20
Samsung Galaxy S20
Battery health not improving after replacement?
Samsung Galaxy S20
