Kenmore Dryer Troubleshooting: Fix Common Problems
The first step towards a working Kenmore Dryer is identifying the problem. Select one of our preferred guides below to diagnose and solve Kenmore Dryer common issues.
Kenmore Dryer Not Heating
Your Kenmore Dryer is not producing any heat. It doesn't warm up to its task. This page will walk you through things to check. Since this is common for electric and gas dryers we will touch on both types.
Kenmore Electric Dryer Error Codes
Has your Kenmore electric dryer thrown an error code? Follow this page to identify the code, and fix the issue.
Kenmore Dryer Won't Turn On or Power On
Is your Kenmore Dryer not turning or powering on? Is there no response when buttons are pressed? Try some of these fixes!
Related Dryer Problems
Gas Dryer Not Heating
Is your gas dryer spinning, turning on, or starting loads, but not heating up? Does the dryer complete, but your clothes are still wet? Try these fixes!
Dryer Smells Like Gas
Your dryer smells like it is leaking gas. The odor may be especially strong when you open the door on the dryer. Here are some steps to take to figure out what's wrong.
Dryer Won't Start
Your clothes dryer is unresponsive, and will not turn on. Seems to be dead, but may show some signs of life.
Electric Dryer Not Heating
Your electric dryer isn't heating up.
Dryer Stops Mid Cycle
Your clothes dryer stops in the middle of a cycle.
Dryer Smells Like It's Burning
Your dryer is making the room smell burnt. Maybe it's even making your clothes smell burnt. It may even be a little smoky. Let's look for the causes and work through the solutions.
Dryer Not Heating
Your dryer spins, but is not heating up to dry the clothes.
Dryer Not Spinning
Your dryer shows some life, but won't spin or tumble the clothes. It's not turning, though there may be a humming sound.
Dryer Squeaking
Your dryer is making those annoying squeaking, squealing noises as it runs.
Dryer Making Loud Noise
Is your dryer grinding, thumping, rattling or rumbling, or a combination of these?
Electric Dryer Overheating
Your electric clothes dryer is running too hot.
Gas Dryer Overheating
Your gas dryer is running too hot.
Didn't see your problem? The iFixit Community has answers.
Browse the most common questions asked by our members to see more solutions. Still no luck? You can always ask for help!
Older Gas Dryer Only Pushed Heat When Buzzing
Kenmore 90 Series Gas Dryer
How do I adjust the feet to my dryer to make it level to the ground?
Why is the gas fire activating in my dryer in the off position?
Noise and sqeaks while running.
