Introduction
Do not look directly into the laser lens. The laser used in the GameCube is a Class 1 laser and can cause serious eye injury. Be mindful when making repairs.
The Basics
Before undertaking any of the more time-consuming solutions below, these are a few fundamentals to get you started.
- Ensure your disk is not damaged: Ensure the game disk is clean and scratched-free. Use a soft, lint-free microfiber cloth to clean the disk in straight lines from the center outward.
- Restart your Console: Sometimes, a temporary software issue can affect how your laptop displays content and requires a hard reset.
- Press and hold the Power Button down until the system resets.
- Once the system is fully powered down, press the Power Button once to turn it back on.
- Close the Disk Cover: Your Game Cube's disk drive will not spin if your console's Disk Cover is open. Your console has a sensor that needs to be compressed by the Disk Cover before it can spin. This is covered more in-depth in this page's Faulty Lid Sensor section.
- Observe any odd behaviors: Look and listen to your GameCube and see if you can see or hear anything unusual. Try to pinpoint if any sounds or behaviors come from a particular component. If your console's laser isn't turning on, the problem is likely with the laser. Alternatively, if you hear any grinding or crunching sounds from the motor, the issue is likely with the drive's motor.
Causes
A dirty laser lens can prevent the disk from being read correctly, causing it not to spin. Power off the console, open it, and look for dust or debris that could obstruct the laser.
Be sure to wash your hands before cleaning the optical laser lens. Dirt, grease, or other leftover particles can prevent the laser from functioning normally.
- Turn off and unplug the GameCube.
- Open the console to access the laser assembly.
- Grab a microfiber or eyeglass cloth and gently brush the lens.
Once the laser lens is dust-free, try starting a game and see if your console can read the disk. Otherwise, if the lens is clean and you can still not restore functionality to your GameCube, you should move on to the next section.
$3.99
4.8
33 reviews
One reason your GameCube's disk is not spinning could be a faulty Lid Sensor. If the Sensor is damaged or otherwise faulty, the GameCube will think that the Disk Cover is open, and the disk will not spin. To test the functionality of the Lid Sensor, follow the steps.
- Remove the Top Case of your GameCube and locate the Lid Sensor in the rear right-hand corner of your console.
- Gently push back the laser lens assembly towards the rear of the console.
- Plug in your console and power it on.
- Gently compress the two prongs of the Sensor and look for any movement from the laser and the disk drive.
If your console does not react when the prongs are compressed, you must replace the lid sensor. Otherwise, try moving to the next section if you get some activity from your console.
- 1 - 2 minutesVery easy
If you have had your GameCube for a long time, your system's disk laser could need to be adjusted so that more power is delivered to the laser. When you make this adjustment, you lower the resistance in the laser's circuit to increase the power output to the laser itself.
Ideally, you will want a multimeter to measure the resistance before adjusting. You don't want to bring the resistance below 100Ω, which can damage the laser. When using the multimeter, touch one prong to the center of the knob and the other to the pin the furthest from the laser's ribbon cable.
- Remove the Optical Drive Assembly from your GameCube.
- Turn the assembly over so the laser faces down, and locate the power adjustment switch as highlighted in the image to the left.
- Use a Phillips #1 Screwdriver, and turn the trim knob very slightly counter-clockwise. Be sure to turn in small increments (Less than 1/8th of a turn). Be sure to measure the resistance after adjusting.
- 30 minutesModerate
$19.99
4.9
28 reviews
If you notice that the laser does not power on, the likely issue with your GameCube is the assembly itself.
- Make Sure Your Laser Assembly is Properly Installed: If you recently reinstalled a laser assembly into your GameCube after a cleaning or refurbishment project, ensure your assembly is installed correctly. Go back through and make sure the assembly is connected and seated properly.
- Check for any damage: Look for visible damage to the laser assembly. This can be any burns or physical cracks in the lens itself. If you see any damage, the assembly must be replaced.
- 30 - 45 minutesModerate
If you hear a crunching, grinding, or any odd sound coming from your console's drive motor, then there is likely some issue with the motor in your GameCube's optical drive.
- Ensure the Spindle Platter can spin freely: Ensure that the platter on which your console's disk sits can spin without issue and is free of dust and debris.
- Replace the motor in the Optical Drive: If sounds come from the motor itself, you will likely need to replace it.
If your GameCube's Disk is still not spinning after following the troubleshooting steps mentioned earlier, there is a high likelihood of a problem with the motherboard.
- Ensure that your device's CPU is adequately cooled. Ensure your console's cooling fan is free of debris and spinning correctly. If you have recently reinstalled your heatsink, double-check that it is correctly attached to your CPU and that the CPU has the appropriate amount of thermal paste applied. Proper cooling is essential to prevent overheating and ensure optimal performance.
- Remove any accumulated dust or debris from your device's internal components. Maintaining proper airflow within your device is crucial. Dust or debris can hinder the cooling process, potentially causing issues with the operating system. Regularly cleaning your device's internals helps prevent excessive heat generation and ensures optimal performance.
- Perform a thorough visual inspection of the circuit boards for any signs of burns or damaged components. Suppose you observe any visible damage, such as burns or parts that appear to be physically damaged. In that case, the board must likely be replaced.
- 20 - 30 minutesModerate
