Causes
Power issues can sometimes be caused by an AC adapter that needs to be reset. Unplug the adapter from both the console and the wall outlet. Wait 90 seconds - it will take at least this long for the adapter to fully reset. Plug the AC adapter back into the Wii U GamePad and wall outlet.
If this did not work, use a different charger.
The GamePad might not be getting a clean connection with the AC adapter. Check to see if the port is clean. Does a charger sit flush against the bottom edge? If it sits at an angle or has a loose fit, the port itself may be clogged. Use a flashlight to inspect.
- Removing debris from a charging port can be a bit tricky due to its narrow gaps. Use an air duster and a toothpick shaved to fit to avoid damaging the port.
- Other non-conductive tools can be used in place of a toothpick, but avoid inserting anything metal into the port.
82 reviews
$9.95
4.8
26 reviews
If the charger works and the charging port is clean, it is likely the battery can't hold a charge, especially if the GamePad won't turn on. Consider replacing the battery.
- 3 minutesEasy
