Samsung Dishwasher Troubleshooting: Fix Common Problems
The first step towards a working Samsung Dishwasher is identifying the problem. Select one of our preferred guides below to diagnose and solve Samsung Dishwasher common issues.
Samsung Dishwasher Normal Light Flashing
Apparent leak? Dishwasher keeps pumping? Let's get you clean dishes again!
Samsung Dishwasher LC Code
Your Samsung Dishwasher is displaying an LC code. It thinks there’s a leak. It doesn’t want to wash anymore. Let’s get you clean dishes again.
Samsung Dishwasher Not Filling With Water
Your dishwasher is dry inside and won't wash the dishes. Let's get your machine full of water again.
Samsung Dishwasher Will Not Power On
No response? Buttons don't seem to do anything? Try these solutions.
Samsung Dishwasher Leaking
Are you finding puddles on the floor near your unit? Let's get it dried up and running.
Samsung Dishwasher Not Draining
Is there water left standing in your dishwasher? Are you getting 5E codes? Try these fixes.
Related Dishwasher Problems
Is your dishwasher full of water at the end of your wash cycle? Is water leaking out onto the floor? Try these fixes.
Dishwasher Not Cleaning
When you dishwasher stops washing the dishes, it has become obsolete. Follow this troubleshooting guide to get your machine running again.
Dishwasher Won't Turn On
Dishwasher won't power on? Try these fixes.
Dishwasher Soap Pods Not Dissolving
When dishwasher soap pods don't dissolve, the dishes inside will remain dirty. Let's figure out the issue and make your glasses shine again.
Dishwasher Stops Mid Cycle
Dishwasher stopped working or turned off mid cycle? Try these fixes.
Dishwasher Leaking
If you're experiencing pools of water on the ground, especially from the bottom of the door, your dishwasher is losing water. If it is an older plastic tub model, look for discolored areas and holes in the tub by shining a bright light under the unit and look in the tub for holes. If there is one, buy some waterproof epoxy to smear around the hole to plug the leak.
Having a dishwasher malfunction can be frustrating, but often, the issues you encounter can be solved with some simple troubleshooting. This guide is designed to help you identify and resolve common problems with your dishwasher right at home. Whether you're dealing with a dishwasher that won't start, isn't cleaning properly, or has a leak, our straightforward steps will assist you in diagnosing and fixing the issue.
Dishwasher Not Drying
What to do when your dishes aren't dry at the end of a wash cycle? Try these fixes first.
Dishwasher Smells Bad
Pee-ew — Dishwasher leaving your kitchen smelly after a load? Follow this troubleshooting guide to solve problem of musty, fishy, or other gross smells from your machine.
Dishwasher Won't Drain
Didn't see your problem? The iFixit Community has answers.
Browse the most common questions asked by our members to see more solutions. Still no luck? You can always ask for help!
Smart Auto Light Blinking
Samsung Dishwasher DMT400
How to reset the normal light flashing
Samsung Dishwasher
Why doesn’t my Samsung dishwasher drain at the end of a cycle?
Samsung Dishwasher
Why is my normal light flashing and if I power off it powers backon
Samsung Dishwasher
Switch in top of door broken on my Samsung dishwasher model DW80K505O
Samsung Dishwasher
Over water tub sensor won't reset
Samsung Dishwasher
My dishwasher is not working
Samsung Dishwasher DMR77
I received the wrong tint on my replacement outer panel
Samsung Dishwasher
