You're seeing solutions for Samsung Dishwasher. Select your model to find parts for your device.
First Steps
You might call these the “unforgettables”. You will never forget it if you dig into your dishwasher only to find out that something simple like one of the items below was the cause of your problem. A multimeter is helpful to test components (like the door switch), but you may get by without one.
Pro tip: Leave the door ajar between loads, as this will help to keep the control circuits dry.
Two initial questions:
- Does the unit respond to some button pushes but not others (like the start button)? If this is the case, go first to Is the Child Lock On?, Next to Start Button Issues below and then go to Control Button Fault.
- Has the unit shown error codes indicating a stuck button, such as Normal and Quick buttons blinking? If so, go directly to Control Button Fault.
Is the Door Fully Latched?/ Door Switch
- Make sure the door is fully shut. Look for jammed racks in the dishwasher or a large item that could be causing the door to strain to stay latched.
- It might also have a pinched, damaged, or misaligned door gasket. Inspect it closely and replace it if you see a problem.
- If the door won’t latch, go to Door Switch/ Latch below.
- If that’s okay, go to the next item.
Check the Power Source
- If your dishwasher is plugged into an outlet, ensure it wasn’t accidentally unplugged. Then unplug it, plug in a lamp you know works, and test the outlet. You can also use an outlet tester to ensure the outlet is wired correctly.
- A tripped circuit breaker could be the culprit. Check to see if the breaker has tripped or has been turned off accidentally. You will have to rely on checking the breaker for a hardwired machine with no cord or plug.
- If power is okay, go to the next item.
Is a Cycle Selected?
Did you select a cycle? The dishwasher won't start if no cycle is selected.
The dishwasher won't start if the child lock is on
Reset the Dishwasher
This step has risks, as you may lose valuable troubleshooting data from error or fault codes. Also, resetting won’t always magically cure most problems. Since the dishwasher won’t turn on, you will have less time to go by because the codes will be erased if you reset the unit.
- To reset the dishwasher: Unplug it or turn the power off at the breaker. Wait 5 minutes, then restore power. No good? Go to the next step.
Start Button Issues
- Especially on a touch-type control pad, a dirty button may fail to register a touch. Make sure you clean the buttons with a damp cloth and mild detergent.
- Also, your hands should be dry; wet hands can also fail to register on touch-style buttons.
- If you came here because the dishwasher responds to some buttons and cleaning the start button hasn’t worked, go ahead and follow the procedure below in Door Switch/Latch to remove the dishwasher from under the counter. You don’t need to check the door switch or latch because the unit responds to some buttons. Then skip to Control Button Fault, below
You must dig in more if these initial steps don’t bring it back to life.
Causes
The first thing to check is the door switch and latch assembly.
- You will have to access the inside of the dishwasher door to see if the door latch is not operating the door switch.
- Observe its operation to ensure the latch is not bent or broken. There are several failures that Samsung dishwashers can experience with the latch, and you will usually have to obtain the latch and switch assembly as a unit.
- You should test the switch for continuity if possible.
At this point, you will need to remove the dishwasher from under the counter. Here is a procedure for doing this:
You should have the following tools and items:
- A straight slot screwdriver,
- A #2 Phillips screwdriver,
- A pair of slip-joint pliers will also help disconnect the hoses.
- A ½” open-end wrench or a small adjustable wrench (probably easier) for disconnecting the water supply hose. Some hoses may need a ⅝” wrench.
- Four wire nuts, so you don’t have to reuse the old ones. Get ones that are suitable for #12-#16 wire. There are special wirenuts that you should obtain, if possible, that are vibration-proof.
- A wet-dry vacuum to pick up water is helpful but not essential.
You will need to do the following steps to pull the dishwasher out:
- Shut off the power to the dishwasher at the circuit breaker panel or by unplugging it if it is connected to an outlet under the sink. This is most critical with hardwired units rather than connected with a plug.
- If the dishwasher is hardwired, open the connection box (usually located at the lower right front of the dishwasher behind the kickplate) and disconnect the wiring.
- Check as you do this that none of the wire nuts or connectors have come loose. Vibration and insufficiently tightened wire nuts frequently cause this. If you find this the case, strip back the wires (they may be heat damaged) and put new wire nuts on.
- A setscrew type of wire nut is recommended, such as the ABB Marrette 1SHD or similar. Replace the wire nuts and test the unit after returning it to its place.
- If the connections are tight, keep going.
- It would be best to disconnect the water supply (usually at the left front of the dishwasher at the bottom behind the kickplate). The ½” wrench is helpful here.
- You will need to disconnect the drain hose, which is best done where the hose connects to the building plumbing (usually under a nearby sink at the garbage disposal).
- Remove the screws securing the dishwasher to the counter or cabinet.
- These will either be immediately above the top rim of the dishwasher or on either side of the dishwasher in the door opening. (If the latter is the case, there may be small covers over the screws)
- Pull the unit out, making sure that nothing kinks. The next step is to check the drain path for kinks since you don’t want to create any. You will also want to check the parts built into the dishwasher.
The dishwasher will have a noise filter installed near the primary power connection. It will have a coil of shiny copper wire mounted on a small circuit board, and the power wires will run from the primary connection straight to it so you can trace the wires to find them. Look for corrosion or burned areas on both the wires leading to it and the PC board itself. If it looks okay, go to the next item.
Did the unit show signs of life, like responding to some button pushes but not others (like the start button), and have you cleaned the start button and tried it with dry hands?
This interface is exposed to considerable moisture, which causes failures. Inspect it for corrosion. Replacing the control button interface (the button module) in the door is probably your best shot if the above items don’t fix the problem. The next step is likely the primary control, but the control button interface is a common failure. It may be hard to find, so you might need to salvage one from another of your same model if possible. Try this and test the unit.
Samsung Dishwashers do not have thermal fuses. To validate this, try to buy one. You will find Samsung refrigerator defrost system thermal fuses. Sadly, many parts companies will lead you astray. A few, mainly European, Samsung models have a fuse on the power supply or EMI filter. Go to the next step if this fuse tests okay.
Check for corrosion on the board. Moist conditions and a primary board location directly under the door are not a good mix. This no-start, no-response, or odd-response problem points to a control board issue if none of the other solutions have worked. This is not uncommon with these dishwashers, but the cost makes it worthwhile to ensure you have checked everything else first.
Additional Information
https://www.applianceblog.com/mainforums...
Door lock engages after opening the door
The above link is an answer that touches on door latch problems and the problem when the latch breaks. You have to replace the latch/switch combo.
https://www.youtube.com/watch?v=FybZsq2f...
A good video showing the main control board replacement.
